Plugs for a lightly modded IX
Old Aug 7, 2007 | 01:45 PM
Kierkegaard's Avatar
Question Plugs for a lightly modded IX
Wondering what I should run on a IX with full tbe, fuel pump, flash, mbc set at 21psi.
Old Aug 7, 2007 | 02:05 PM
Mitsu3's Avatar
stick with the stock ones
Old Aug 7, 2007 | 02:15 PM
Tsurugi-san's Avatar
Until you've done a full set of bolt-ons, and are dying to turn up the boost and perhaps alter your fuel mix ---- stockers are fine. When the inevitable finally occurs, you'll probably want to run a step colder plug. Lancershop will sell you colder iridium NGK's for $144 a set, or Nolimit will sell you colder iridium Denso's for less than half of that. NGK versus Denso? Ask for Chris at nolimit.
Old Aug 7, 2007 | 02:49 PM
can i switch to copper?
Old Aug 7, 2007 | 02:51 PM
Sap12687's Avatar
no
Old Aug 7, 2007 | 05:12 PM
BlueDemon's Avatar
+1
Old Aug 7, 2007 | 05:15 PM
fimotorsports's Avatar
+2 stick with the stock ones
Old Aug 7, 2007 | 08:23 PM
vwjeff's Avatar
Stock ones are just fine.
I ordered 2 step colder NGK's and I am gonna tune them in Thursday.
Old Aug 7, 2007 | 08:42 PM
Warrtalon's Avatar
there aren't any for the IX, but even if there were, why would you want to? You'd be removing a $60 set of plugs that work great and last 60k miles while inserting an $8 set of plugs that isn't needed and only lasts 5k miles. I'm curious as to why you'd want to remove perfectly good parts to replace them with lesser parts.
Old Aug 7, 2007 | 09:26 PM
PC325xi's Avatar
stock IX plugs last 60k miles?
Old Aug 7, 2007 | 09:32 PM
Warrtalon's Avatar
Iridium plugs can last 60k miles, and the stock plugs are Iridium.
Old Aug 7, 2007 | 09:37 PM
red evo8's Avatar
denso ikh24 are 2 step colder for the ix's optionsauto sells them for like 45 plus shipping for all
Old Aug 7, 2007 | 09:38 PM
Warrtalon's Avatar
2 steps colder? That sucks for most IXs, which would want 1 step colder at most.
Old Aug 7, 2007 | 09:44 PM
AlohaEvo's Avatar
I was thinking the same thing
Old Aug 8, 2007 | 06:58 PM
vwjeff's Avatar
explain why?
I run 11 steps colder in my GTI, for more boost on pump. So how is 2 bad
