What boost?
Old Aug 8, 2007 | 06:15 PM
upstatescevo's Avatar
What boost?
What kinda boost should i be hitting on just wastegate? I hit about 20 and fall to 15. Is that normal or do i have a boost leak? The car is an 03 with about 80k on it
Old Aug 8, 2007 | 06:22 PM
ak47po's Avatar
12lbs just wastegate.20 to 15 is a little much.Probaly need new spring in MBC or a cleaning.
Old Aug 8, 2007 | 06:24 PM
no thats what i am hitting with nothing hookd up to the wastegate no boost controller or lines just open
Old Aug 8, 2007 | 06:25 PM
EvoLutionized8's Avatar
+1^do you have an adj. WG??? that is quite high
Old Aug 8, 2007 | 06:27 PM
no stock that is what i was wondering should i replace the wastegate acutator with another one this one has about 80k on it and when i have the manual boost controller hooked up i can only hit 5psi
Old Aug 8, 2007 | 06:31 PM
mplspilot's Avatar
wow ur sig says you got 2 o2 housings! Very nice, I like! How much?
its probably because of one of them, it should be 12
Old Aug 8, 2007 | 06:37 PM
nah it was doing this before the custom o2 housing setup
12psi is for the stock wg.. and if you are only boosting 5psi after u plug up the MBC, then it sounds like you got your tubes crossed, if you know what i mean.. hehe..
Old Aug 8, 2007 | 06:44 PM
nah i have it hooked up right
Old Aug 8, 2007 | 06:47 PM
But i can fix that i was wondering about the wastegate why such high boost on just wastegate? i mean it goes straight to 20 and then falls to 15
