shift lingage problem
Old Aug 12, 2007 | 05:47 AM
adamhw's Avatar
I have the exedy twin with 15k. Almost no abuse seen to it. It's drove fine with no issues.
I go get in the car, and can not get the car in any gear while the car is running. I can shift fine with/without clutch when car is off. Clutch pedel depresses with some resisntance, however it doesn't feel like it is doing anything. I'd guess no disengagement. I was thinking master/slave cylinder breakage or worse.
Any ideas, and how much should the repair cost be. The car is at the delarship, but they still haven't even looked at it. Thanks for the help.
Old Aug 13, 2007 | 03:54 AM
adamhw's Avatar
bump.
Old Aug 13, 2007 | 07:41 AM
AlwaysinBoost's Avatar
being able to get into gears with the engine off w/o using the clutch but NOT being able to get in gear with the engine spinning and the clutch pedal being depressed usually points to a problem with the clutch.
Your best bet is to first check the small things. Make sure you getting full travel of the clutch pedal and that there is no air in the system.
Old Aug 13, 2007 | 07:42 AM
edit: just saw you already have it at the dealer... good luck.
Old Aug 13, 2007 | 01:48 PM
adamhw's Avatar
looks like the clutch I'm looking for new disks, and maybe more.
