Help Me Spend my Money!! ~4k
Old Aug 13, 2007 | 11:30 AM
520hpsti's Avatar
Originally Posted by money pit
holy crap i can't believe you wouldn't just get my car. i thought you didn't want an evo?
John, it was either my Bros evo, or a luxury / non performance car. I love your evo though and would love to have it.
Originally Posted by grenade
Your paying 33K for a stock 03 evo??
No, I sold my STi for 33k and am giving my Brother that money to buy a nicer car like a TL or something. He has a 03 BBY VIII right now and i will be taking his car.
Originally Posted by E\/0IXG$R
Buschur UICP
Buschur LICP
Buschur Race FMIC
Ebay 3" Catback
High flow Cat
Megan DP
Buschur Ported exhaust manifold
Ebay 02 housing (ported & coated)
10.5 Hotside (ported)
Forge UNOS MBC
Forge Wastegate Actuator
Walbro 255lph
S1 Cams
Apexi Power Intake (cleanest filtering intake for evo)
Apexi Heat shield
Head studs
Oil Catch can
Tune
Call it a day
Thanks for the input man. The ebay catback is really loud, right?
Originally Posted by boostinpsi
id run your original list + meth and then get yourself some nice coilovers.
I can't lower the car, the roads in STL are too ****ty and there are too man inclines.
I like my original list too.
btw if you paid that much for a stock 03 you got ripped off. i paid 25 for my 05
I am not paying anything for this car. My brother is giving his car to me and i am letting him use the money from my STi sale to get a nicer car.
Old Aug 13, 2007 | 11:35 AM
SickSilverNLow's Avatar
Here is what i would do:
ETS 3.5 FMIC.
ETS short route UICP and Lower IC pipe.
ETS Mini Battery kit.
ETS intake.
AEM tru-boost controller/Gauge
AEM wideband
ETS TBE
720 injectors
Fuel Pump
HKS cams 272s
Head studs
Rod bolts
And................get her tuned by a good tuner . Good luck.
Old Aug 13, 2007 | 11:36 AM
Soon2BEVO's Avatar
Originally Posted by 520hpsti
I was also considering meth, but i am not sure about having it on a DD.
Thanks for the input.
Where can i buy the ported stock manifolds, hotsides and 02 housings?
I have meth on my car, I used to daily drive it, its fine, and great. It really is. You can get ported/coated parts from
Buschur Racing
PPI (Paradigm Performance)
I got my turbine housing ported from BR, and my manifold done at PPI. Both do a great job.
Old Aug 13, 2007 | 11:39 AM
E\/0IXG$R's Avatar
It's kinda loud, but liveable. And if you run the Buschur, Nisei, or AMS short IC pipe kits your going to need a mini battery. Just about everyone makes them nowadays, shouldn't have any trouble finding one. You're going to have some fun!
Old Aug 13, 2007 | 11:45 AM
520hpsti's Avatar
Yah man, im excited to start my own project. I know ETS makes some pipes that work with the stock battery, but its a good excuse to get a mini battery
Old Aug 13, 2007 | 12:58 PM
ETS Michael's Avatar
You can hear our evo exhaust system on the main page of our website.
Old Aug 13, 2007 | 01:32 PM
520hpsti's Avatar
Thanks
Old Aug 13, 2007 | 01:36 PM
No problem man, if you need anything let us know. Good luck man!
Old Aug 13, 2007 | 01:40 PM
520hpsti's Avatar
Will do and thanks alot!
Old Aug 13, 2007 | 01:46 PM
MIVEC8's Avatar
BLOX 272 cams $300 (install $200)
Evo IX turbo $500
O2 housing-Titek $150
TBE Tanabe dp, cat delete, XXX exhaust $7-800
Hallman Pro MBC $80
Custom Dyno tune $4-500
Boost gauge $150
Nisei LICP $150
MAF Adapter w/ KN filter
Walbro 255 $80
Denso 720cc injectors $380
ARP Headstuds $100
JDM MR BOV $100
You will still have some left over.
Maybe port your ex manifold and turbo.
Old Aug 13, 2007 | 01:53 PM
MIVEC8's Avatar
The lower intercooler pipe is the only one worth upgrading. You wont find much more hp in an upper ic pipe.
Save the intercooler upgrade for a bigger turbo, the OEM is rated up to 400hp.
You don't need a mini battery yet.
I wouldn't suggest meth for daily driving. Many do it w/ no issues but if anything fails kiss your block goodbye.
If you're VIII is still running the 9.8 hotside at least upgrade that or just pick up a used IX turbo and sell your old turbo to help alleviate some of the cost.
Old Aug 13, 2007 | 02:01 PM
520hpsti's Avatar
Thanks for the input guys! keep it coming
Old Aug 13, 2007 | 02:35 PM
NIevo's Avatar
Thats what I was thinking?
Old Aug 13, 2007 | 02:49 PM
GEJEN's Avatar
I bet your brother is still smiling.
Old Aug 13, 2007 | 02:50 PM
erioshi's Avatar
Hmm - 4k to spend on a stock VIII and looking for good, street friendly power?
I would skip the 10.5 hotside and just buy a good used Evo 9 turbo - until you compare the 8 and 9 turbo side-by-side you won't understand the difference. Some good cams (the GSC S1 seems like a solid choice), a full 3" exhaust with an ebay down pipe and a Walbro 255 fuel pump. Be sure to get a solid custom tune. Oh, you will need some form of boost control, either manual electronic. I prefer an EBC or ECU based solution that doesn't require adjusting boost every time the temps change. The stock airbox & FMIC are decent enough for the power levels with the mods above.
Along with those mods I would also add ARP head studs (or equivalent), along with ARP rod bolts & main bearing studs. I lost an engine to spun bearing because of a stretched rod bolt - something I could have easily prevented.
After that I'd grab some good wheels & tires. If you are considering suspension mods get help from someone like Robi; it's easy to make the car feel different without actually improving it's handling.
