blew up!!!!
Old Aug 18, 2007 | 01:14 PM
nubi4life's Avatar
blew up!!!!
ok i was racin my car and all of the sudden my boost for my turbo stopped and it was as if my turbo stopped workin. then when i stopped the car. this blue smoke was coming out the back of the car everywhere.. and i could hear a wierd noise coming from the turbo. is my turbo and engine shot??? whats a good place to rebuild turbos. please help!!
Old Aug 18, 2007 | 01:25 PM
housedj's Avatar
if ur asking us for help, how do u know that its the turbo? looking at the mods in ur sig, we would all assume that u at least have the common sense to monitor what ur motor is doing?
what kind of "racin" were u doing since u can't spell it correctly???
Old Aug 18, 2007 | 01:55 PM
High_PSI's Avatar
Blue smoke is oil.
Old Aug 18, 2007 | 02:01 PM
Greg K's Avatar
need more data. did you feel a loss of boost?
if so, my guess is that the bearings/bushings in the turbo went. this causes the shaft to wabble, the compressor blade rubs the housing, fins shear off, and get caught in the I/C.
the loose shaft allows oil to leave the bearing/bushing surface and blow into the exhaust.
I've seen this more than a few times on various rally cars.
evo8fl's Avatar
turbo is gone, can't rebuilt garret turbos
Old Aug 18, 2007 | 10:33 PM
nubi4life's Avatar
so i guess buschur racing uses garret turbos. dam. so when you mean its my oil then what. what do you think the problem is. im talking about a whole bunch of smoke and i hear rattling from the turbo. please help
Old Aug 18, 2007 | 10:42 PM
boostinpsi's Avatar
your turbo blew up....you need a new one. the seals in the turbo went out so oil leaked out went through the ic pipes, ic, throttle body, intake mani, into the cylinders where it burned and caused blue smoke to go out your exhaust.
be sure and check everywhere else to make sure there are no little metal bits waiting to go into your motor when you button it all back up.
gt35r = garrett turbo 35r
Old Aug 19, 2007 | 07:32 AM
nubi4life's Avatar
i dont understand why my turbo blew. im running 410 awhp on 21 lbs. turbo trix tuned my car. how could something like this happen. im in germany and i was on the auto bahn pushing my car. then when i was just cruisin thats when it just stopped working. every time i try to boost the car i hear grindin coming from the turbo. and some smoke comes out the engine where the turbo is. you guys dont think i need a new head do you??? this is the second time my 35r from buschur went out.
Old Aug 19, 2007 | 07:49 AM
revvin9k's Avatar
With all due respect..... why are you still trying to boost the car let alone drive it without diagnosing the problem first?
Old Aug 19, 2007 | 07:51 AM
bluebyu36's Avatar
do a compression test
Old Aug 19, 2007 | 07:56 AM
Sharkbite2000's Avatar
You have problems
Old Aug 19, 2007 | 10:06 AM
nubi4life's Avatar
ok so someone please tell me exactly what to do. is all i need a turbo and to clean my **** out?? cause the smoke only happens when i accidently boosted it to drive it back on my base. ill buy the turbo. thats no prob. i know how to bolt that on. but is there anything else i need to do?? lemme know.
Old Aug 19, 2007 | 04:28 PM
BoOsTinGEVO190's Avatar
take your intake off look inside your turbo i mean i dont know that much about this either but common sense dude take a look inside the turbo spin the wheels see if it moves allot = shaft play good luck
Old Aug 19, 2007 | 04:32 PM
Bonestock!'s Avatar
Your pushing the car hard on the Autobahn and wonder why its breaking? Most tunes are for drag racing and/or peak numbers. Next time get the car tuned for road racing and stop driving like your *** is on fire.
Old Aug 19, 2007 | 11:17 PM
nubi4life's Avatar
so is all i have to do is switch out my turbo and clean what you guys said?? if so whats the exact proceedure?? any website you guys recommend to help me out??
