Buschur Racing Mustache Bar, Center Member & Rear Diff Bushings *Updated Pics & Info*
Old Aug 29, 2007 | 09:01 PM
midwestmonster's Avatar
Jrod, How hard is the mustache bar to install? How long do you think it would take without a lift?
Old Aug 29, 2007 | 09:08 PM
wizzo 8's Avatar
I hope I didnt miss it but can you get the mustach bar with rubber bushings to help with a DD?
Old Sep 4, 2007 | 07:37 AM
Asmodeus6's Avatar
Thats my thoughts. If you'd like to eliminate the dreaded BUMP, and the weight. Can you just run the front support bushings from ES? (instead of solid aluminum?) I can't help but dig into the throttle on this car... and I get bumped often.
But it is a D/D car that sees its share of quick shifting.
I really want this resolved. (I bought it as a car you guys dyno tuned, with basically all of your parts) From a design standpoint your RMB is more confidence inspiring. What do I need w/o overkilling it? Noise isn't a problem if its safer on the drivetrain.
Old Sep 4, 2007 | 08:06 AM
Jrod@Buschur's Avatar
The bar itself comes with its own metal bushings in the end. They are NOT the same as the ones sold seperately. You could still order the energy suspension urethane bushings from us for a "not so race" application.
Old Sep 4, 2007 | 10:39 AM
Asmodeus6's Avatar
Will the bar alone with its standard metal bushings be enough to stop it from bumping? Or do I need anything else?
Old Sep 4, 2007 | 11:14 AM
StreetThisEvo's Avatar
<< I will be buying these great BR parts when I come in to drop off my transmission and transfer case to Daniel this coming Monday
Old Jan 1, 2009 | 01:46 PM
Johnboy1065's Avatar
the stock front center member has a spot to where you can jack up the front of the car. with out that where is the best place to jack it up??...just curious
thanks,
John
Old Jan 5, 2009 | 07:20 AM
Personally I always used the jack points on the sides.
Old Jan 5, 2009 | 06:14 PM
wizzo 8's Avatar
So how much would that be with the energy bushings?
kpt6
Sep 22, 2015 08:40 PM
the mark w
Jun 20, 2011 10:23 AM
Jrod@Buschur
EvoX 'For Sale' Miscellaneous
Jan 30, 2009 10:47 AM
Jrod@Buschur
Evo 'For Sale' Miscellaneous
Jan 30, 2009 10:46 AM
Jrod@Buschur
42
Jan 1, 2008 05:34 PM
