What head bolts to run?
Old Aug 29, 2007 | 10:40 AM
PATRICK B.'s Avatar
Buliding a o-ringed 2.0L motor w/ a 35R planning to push about 30-35psi.
Wondering what the general consensus is in regards to brand to run.
This should put down over 500awhp on a Mustang Dyno similar to Buschur's.
Good friend of mine was mentioning Magnus sells some pretty stout stuff that costs around $350 for a set but can be re-used.
He also mention ARP L19 (i think) that are better than the standard ARP stuff but a little cheaper than the Magnus stuff?
Can you point me in the right direction.....the shortblock comes back from the machine shop any day now
Old Aug 29, 2007 | 10:47 AM
TeStUdO's Avatar
You cant go wrong with ARP Head Studs. The undercut ones supposedly have a higher tensile strength. I havent seen any documentation backing it up though.
Old Aug 29, 2007 | 10:49 AM
Spookpur's Avatar
I plan on going with the AMS headstuds... http://www.amsperformance.com/store/...oducts_id=1090
Old Aug 29, 2007 | 03:42 PM
Jackson Machine's Avatar
You'll never exceed the capabilities of the ARP's.
Old Aug 29, 2007 | 04:58 PM
PATRICK B.'s Avatar
You mean just the standard 120 ones
Got a part # for the ones you rec'd for my application?
Do you re-use them?
Old Aug 29, 2007 | 05:02 PM
caLi4G63's Avatar
The AMS ones are overpriced, like JAM stated, the ARPs are more than enough, they've been proven to work countless times.
Old Aug 29, 2007 | 05:14 PM
Autoilluminate's Avatar
The AMS studs are a really good price for L-19 hardware. But if you aren't planning on making 800+ whp they are overkill. The standard ARP's are fine for a 500whp car.
Old Aug 29, 2007 | 07:08 PM
Luis@TTP's Avatar
+1 arp L-19s what he said^
Old Aug 29, 2007 | 07:42 PM
CO_VR4's Avatar
Undercut studs don't have more tensile strength. They spread the stress more evenly along the length of the stud.
Old Aug 29, 2007 | 07:47 PM
kngnothg's Avatar
ARP (standards) run 120ish
ARP (L19s) run 250 ish
for the extra money, i would get the L19s, especially if i was going to build a strong motor.
Spooldyou's Avatar
I ran the ARPs on my car. Made 450
Old Aug 29, 2007 | 10:13 PM
evovin's Avatar
Arp
Old Aug 30, 2007 | 06:27 AM
TeStUdO's Avatar
Ahhh, ok. Thanks for the info. I have seen the domestic engine guys put a ball bearing in before putting the headstud in. Have you guys ever heard of or seen that?
Old Aug 30, 2007 | 07:12 AM
Do you re-use them?
207-4203, we have them in stock for $109.
And we do reuse them as long as they haven't been over-torqued or damaged. We've used the standard grade ARP studs in EVO's making 650+WHP without o-rings and domestics over 1000HP with no problems.
Old Sep 4, 2007 | 09:28 AM
PATRICK B.'s Avatar
I ended up ordering some from AMS........hope to not have any sealing issues for a while
