Who is FASTER? Shep or Trans
from shep website:
ShepTrans.com EVO - EVO Upgrade/Rebuild We take your trans and apply all applicable tsb's and updates as well as modify the oiling system and a few other tricks to make it shift. This trans build is used by the quickest and fastest Evo's around including both the AMS drag car and time attack car, AL (dynoflash), Buschur Racing, Curt Brown, Pruven Performance,Dan Bajalis , Proco Evo and many more.
EVO Upgrade/Rebuild Includes the Following:
Price: $895.00 - plus $85 shipping and insurance
From TRE:
This is our Stage 1 rebuild service for the Mitsubishi EVOLUTION 5 speed. This rebuild includes all current Technical Service Bulletins and updated part numbers. If you're wanting an excellent shifting transmission, yet on a budget, this would the way to go.
The parts replaced:
New 1-5th & Reverse synchros
New 1st-2nd hub & sleeve
New 3rd/4th hub & sleeve
New 5th/Reverse hub & sleeve
New 3rd/4th shift fork
New Input shaft bearings
New output shaft bearings
New oil seals
New synchro springs
New heavy duty Neodymium trash magnet & magnetic drain plug. Keeps the oil clean.
New snap rings, heavy duty double roll pins, end nuts, bearing shims and all the other non-reusables that you would expect to be replaced in a quality rebuild.
More info about Stage 1
5 SPEED EVOLUTION STAGE 1 REBUILD = $900.
UPGRADE OPTIONS
These are the current options for the STAGE 1 EVOLUTION transmission.
Electropolishing (REM ISF®) of hub & sleeve, shift rails, add an additional $200.
EVO-9 taller 1st gear & input shaft, add an additional $325.
EVO-8 taller 4th gearset, add an additional $200.
EVO-9 taller 5th gearset, add an additional $200.
EVO-9 short 5th gearset, add an additional $200.
Shot peening, add an additional $350.
4.11 final drive, add an additional $1100.
3.73 final drive, add an additional $1000.
Warranty is 12 months.
shep and tre are both GREAT. also dont forget about buschur. https://secure.buschurracing.com/cat...8a93810e19a68e
your going to get great service at any of those shops!
Shep fpr sure, when building my talon I went with John. He really helped me decide what was best for me. Too bad what was really good for me was a $6000 dox box, but as he put it spend it now or keep rebilding a stage 3. The customer service is fantastic. My dox box was built in less than a week.
I would do a TRE trans, I have had several from him and they are great. Plus I have been at his shop and watched him work on the trans, it is amazing the detail work on the gears and how the trans is assembled.
a dogbox is a gearset that, simply described, has slots cut around the side of the gears, and a "pin" in the corresponding side of the matching gear. When you shift, which you have to do under deliberately strong shifter pressure, the "pin" pushes against the side of the other gear and hits one of the slots within a 1/3 rotation, immediately bringing it up to the same RPMs. Some people say that they pick up 1/2 second in the quarter mile using a dogbox. Rally cars use them as well.No clutch needed except to start, just a slight reduction in the power. They must be shifted very positively, or the pins/slots suffer damage. You change the transmission fluid every 1000 to 1500 miles (or less, depending on how hard the use is). Most of the dogbox gearsets are straight cut, and are kinda loud.
I have had 5 or more TRE transmissions, including two Stage III Evos, and several Stage III DSM transmissions. I've never had a failure, and they shift fantastic. I've spoken with Jon, the owner of TRE, on a number of occasions, and he'll spend 30-60 minutes at a time explaining what he would recommend and why.
He now has EVo transmissions in stock for exchange as well, so that can be a pretty quick turnaround if you need one in a hurry.
I've also had a Shep DSM transmission, and it works well too.
+1 for TRE, sorry guys - we have not experienced what you have this week. We called Shep and TRE and emailed both. Shep was too busy to talk on the phone and didnt respond to emails. Jon at TRE on the other hand spoke with me at length and answered all of my questions and answered my email promptly as well. I think the service level that you recieve just depends on how busy they are at the time and all of these un-substantiated "<fill in the blank> is best with no reasoning should not be a determining factor IMO".
I literally had to threaten them with posting our experience before he would even contact us back via email, let alone the phones...
Shep is real. He will treat you the same before and after you make your payment. Being busy is not a bad thing. I know Shep just had to put about $4000-6000 into a phone system there to help deal with the volume of calls.
thats funny right there Scott
