Max boost on 100 octane?
Old Sep 7, 2007 | 12:31 PM
thelza23's Avatar
I currently have a BR stage 1 and about to port and polish the exhaust manifold and get megan 02 housing. I plan on a retune on 100 octane and was wondering what the max amount of boost i can run? what are some of you guys running with a similar set up? I was thinking of running 25-25psi.
Old Sep 7, 2007 | 12:38 PM
scherejs's Avatar
I believe this question was answered over in the general section.
Old Sep 7, 2007 | 12:41 PM
thelza23's Avatar
just wanted to post in right forum
Old Sep 7, 2007 | 12:44 PM
Dead-Man Inc's Avatar
you might need headstuds to boost a bit over 25 PSI
Old Sep 7, 2007 | 01:57 PM
kreionic's Avatar
The question is to vague. You can as much boost as you want really. You need to factor in A/F and timing. If you keep the timing the same as it is on pump gas you can get away with higher boost. If you ramp up the timing then you will not be able to boost too high. This goes for all gas really
