View Poll Results: What headgasket concotion are you using?
Stock
30
60.00%
HKS
10.00%
Greddy
2.00%
Cometic
18.00%
Stock + o-rings
4.00%
HKS + o-rings
0%
Greddy + o-rings
0%
Cometic + o-rings
6.00%
Voters: 50. You may not vote on this poll
550+whp...What headgasket are you using?
Old Sep 7, 2007 | 09:58 PM
ExViTermini's Avatar
As the question states, what headgasket are you guys using for high power? And are you o-ringed?
Old Sep 7, 2007 | 10:00 PM
riceball777's Avatar
most ppl run stock head gaskets i think even on high power evos
Old Sep 7, 2007 | 10:13 PM
34Turbo's Avatar
Cometic
Old Sep 7, 2007 | 10:24 PM
evo_08's Avatar
hks hks hks hks hks hks
Old Sep 8, 2007 | 08:14 AM
Chris@nolimitmotors's Avatar
I ran a cometic, 35 psi on a 35R and had no problems. My head and block were not o-ringed.
Old Sep 8, 2007 | 09:06 AM
superflyevo's Avatar
this is funny , i was trying to figure out what head gasket i am gonna use for my build
Old Sep 8, 2007 | 09:53 AM
Paul Nelson's Avatar
We have the AMS Head Studs,cooper o-ring and stock head gasket did fine to 54 psi
On my old setup we where not o-ringed but ran the AMS Head Studs to 110ft lbs and a stock head gasket
Old Sep 8, 2007 | 09:56 AM
Soon2BEVO's Avatar
If ifarted2 is using the stock one, anyone can. I think for 40psi+ O-ringing the head is a very good idea. ARPs are a must.
Old Sep 8, 2007 | 01:37 PM
Luis@TTP's Avatar
stock +1 mitsu metal = good stuff
Old Sep 21, 2007 | 01:59 PM
RanEvo's Avatar
I am not a vendor, so I have no interest…. Us anything except COMETIC!!!
Old Sep 21, 2007 | 02:30 PM
DTM's Avatar
DTM
Use the stock gasket.
Old Sep 21, 2007 | 02:31 PM
DTM's Avatar
DTM
Explain to me why you would choose to oring the head
Old Sep 21, 2007 | 02:44 PM
AlohaEvo's Avatar
stock, o-ring, AMS head studs
Old Sep 21, 2007 | 02:48 PM
swordfish's Avatar
You DO know that running a Cometic gasket requires a certain RA on the block and head right? If you just stuck it on and your machinist didnt have any idea about this the gasket probably failed because he ran normal table speed while decking the surface. High table speeds result in rough finishes and Cometics will not seal. I suggest hand lapping when using Cometic gaskets. Havent had one fail yet.
The the original poster. If you're not trying to set the world on fire, stock will be fine.
jeff
