evo clutch website
Old Sep 9, 2007 | 03:00 PM
3_diamonds_'s Avatar
evo clutch website.would you try it?
would you put one of these in your evo?prices are good.
http://www.clutchnet.com/search.php?mode=search
Performance Level:
Red:Racing
Yellow:Hi-Performance
Green:Steet Upgrade
Old Sep 9, 2007 | 09:50 PM
mlancerevo8's Avatar
need help asap
i have a 05 evo8... i am doin my clutch install and i have one major problem.. my throw out bearing is stuck/ceased to my pressure plate... anyone know how i can get it off? i have been prying on it and everything i can think of and it still wont budge... please need help...
Old Sep 9, 2007 | 10:05 PM
Evo8luva's Avatar
there is a way to pop the bearing out the pressure plate, you need a long screwdriver, put it through the inspection hole on the bottom on the trans and squeeze it between the bearing and the plate and if you kinda twist the screwdriver and pry the right way you can get it to pop out
Old Sep 9, 2007 | 10:11 PM
EvoKnievo's Avatar
i had this same problem, i guess i wasnt prying in the right spot. but yeah just pry between the plate and the bearing
Old Sep 9, 2007 | 10:13 PM
keevo54's Avatar
haha thread jack ftl
Old Sep 9, 2007 | 10:17 PM
bluebanana23's Avatar
i would try the discs but if i'm already paying for a clutch job might as well upgrade everything but i'm only saying this because i'm still on the stocker
Old Sep 10, 2007 | 05:17 AM
skold's Avatar
this will help with tb coming out
http://evomoto.com/tech_info.php?tec...f26974d81017ed
Old Sep 10, 2007 | 07:29 AM
Luis@TTP's Avatar
or there is a cut out on the back of the transmission that is a rectangular shapped with little squares in it. us a chisel and knock that out and just pull the pressure plate bolts. If all else fails hit the TOB fork with a hammer you wont bend it. You would pop the retainer clip out. of the pressureplate itself.
