WHat is the best turbo for 100 octane
Old Sep 10, 2007 | 09:20 PM
stiklr's Avatar
I need help deciding on a turbo size for my set up.
I have FMIC, BR TBE, BR UICP, 272/272, headstuds, 680cc inj, fuel pump, mbc, APS BOV. Stock bottom, head, intake mani, TB.
I have seen great results with 93+meth on many turbos, I don't know if 100 octane fuel can net the similar results.
I would like to know which turbo will work best with 100 octane fuel. I am looking for the best powerband and 500 dynojet horses.
Green, 50 trim, 3076, 3065, 35r ????
Old Sep 11, 2007 | 12:35 AM
riceball777's Avatar
a 50 trim bb or a 3076r would be nice on 100 octane
Old Sep 11, 2007 | 01:54 AM
spdracerut's Avatar
Turbo size pretty much only depends on how much horsepower you want. The actual ability to get that horsepower depends on the boost pressure required. That in turn is dependent on fuel octane.
You can run a GT42 but if you're stuck with 93 octane, you're still limited to 25 psi or whatever.
Old Sep 11, 2007 | 06:24 AM
gamebred26's Avatar
Ok so what if you do not want to use meth or race gas and stick with 93 octane..what turbo at 25psi will make the best streetable power?
for an all around evo..not too much lag...
i want to build my car to be a mid 11sec drag car and also a great road race car...400whp should do it...
what can that be achieved on ? on 25 psi pump gas?
Old Sep 11, 2007 | 06:26 AM
scorke's Avatar
I'd say a 3065 or a 30R.
Bigger turbos require more boost to make use of there big size.
Scorke
Old Sep 11, 2007 | 06:30 AM
gamebred26's Avatar
That is what Yo-Solo was suggesting this weekend as well...the 30r...I am a noob to this ****. Coming from the Honda scene and being " anti-turbo "...lol...I sold out!!!
But I love this car and am used to the power already..lol!!!
Old Sep 11, 2007 | 06:37 AM
rr06rs's Avatar
As far as powerband goes, I think that the green or 50 trim takes it. 50 trim may have a slight edge on top end at the cost of some low end. I still say the green is the ultimate daily driver street turbo for our cars though.
Old Sep 11, 2007 | 06:38 AM
scorke's Avatar
Green is great bang for the buck.
Scorke
Old Sep 11, 2007 | 06:39 AM
gamebred26's Avatar
what is the max power to the wheels on average that can be achieved on pump with the green, no meth at 25 lbs. ?
with all the other supporting mods...bolt ons etc.
Old Sep 11, 2007 | 06:48 AM
rr06rs's Avatar
I'd say somewhere right around 400
Old Sep 11, 2007 | 07:03 AM
gamebred26's Avatar
hmm...
Old Sep 11, 2007 | 08:48 AM
Jeff_Jeske's Avatar
I had better results with alchy and 93 than I do with 100 octane. The alchy/meth keeps the intake temps much lower and there is added benefit from this.
The lastest and greatest hype has been E85. If available to you its the best of both worlds.
Attempting to stay on topic.... Race fuel is normally needed only for high boost. The stock turbo run ragged would benefit more from race gas than a 50 trim at the same boost level.
As for the FP Green..... It's a great choice if you are willing to purchase all supporting mods AND you have a great tuner. In all honesty I think most power hungry people will outgrow it.
Old Sep 11, 2007 | 08:58 AM
stiklr's Avatar
I think I had better results when I had 93+ alky, but I was always worried about the alky pump failing, and I was getting an unever mixture, as my AFR were all over the board when I was on the dyno with wideband.
I just feel more confident as far as safety goes with running 100oct 24/7.
Will 100 support 30psi on a 3076 or 35r?
Old Sep 11, 2007 | 09:03 AM
gamebred26's Avatar
do you guys use the alky on dd's? how much do you go through per week normal driving etc.?
Old Sep 11, 2007 | 11:45 AM
OKIX's Avatar
it is really tough to beat the fpgreen (20glt). I have it on my car and run 100oct. daily at 30+psi. On the track I run very consistant mid 11's with my best being an 11.3@121. However Im getting ready to be in the 10's.
