Would you trust this MBC?
Old Sep 12, 2007 | 12:13 AM
Celica2EVO's Avatar
Just wondering how this would work, of if ebay MBC are garbage like half ebay stuff is!
http://cgi.ebay.com/ebaymotors/Manua...spagenameZWDVW
Old Sep 12, 2007 | 12:14 AM
tripperfx3's Avatar
It looks like a turbosmart knock off. I wouldnt trust it though.
Old Sep 12, 2007 | 12:18 AM
Celica2EVO's Avatar
Or what is a suggested MBC that doesnt cost abunch? Im not planning on running a high psi, mainly want to get rid of taper! What is a trusted MBC? Also looking at a TURBO XS MBC?
Old Sep 12, 2007 | 12:19 AM
DJmarkymark's Avatar
id rather go with a proven one (hallman, forge, dejon tool)
a mbc is something i dont want to gamble with, especially since the good ones arent that expensive
Old Sep 12, 2007 | 12:22 AM
wiseguy9's Avatar
dejon tool or joe p mbc. If you want to have a little more bling I'd go hallman...
Old Sep 12, 2007 | 12:24 AM
tripperfx3's Avatar
Hallman FTW! The turboXS is trash. I had it and swapped it out for the Hallman. Improved spool and taper reduction. I have an VIII and it doesnt taper that much. Im hitting 21psi and it drops to around 19 at redline. I saw you requested a quote from Ultimate CC. Hes a great seller and the MBC is worth the money. I think i paid 95 shipped. Maybe a little bit more.
Old Sep 12, 2007 | 12:27 AM
Celica2EVO's Avatar
yea i did, is it safe to run at 21 psi completely stock?
Old Sep 12, 2007 | 12:30 AM
tripperfx3's Avatar
You should get tuned. It should be alright since the evo's run pig rich from the factory, but you might not get much from it without a tune. The older turbo cars like the SR20DET from nissan you could put a boost controller and bump it up from 7psi stock up to 14psi with no problems. But these damned newer cars you gotta tune to get the most out of it . Honestly a better 1st mod would be a turboback exhaust. I know its alot more expensive, but you'll get a lot more out of it.
Old Sep 12, 2007 | 12:37 AM
Celica2EVO's Avatar
well i just got it a couple weeks ago, this is the mod list i have, in order of how it will probly get done:
Hallman MBC
K&N Filter w/adapter from AMS
Walbro Fuel Pump
02 Housing from AMS
Buschur 3" TBE
ECU Tuning Software (friend can tune)
GSC 272 Cams
Hopefully this set up will get me mid-low 12s and 300+ awhp! Im not sure though bought that...clearify if im wrong!
Old Sep 12, 2007 | 12:41 AM
tripperfx3's Avatar
Path looks good, but dont forget a fuel pump and headstuds when you do the cams. Depending on the dyno you should make over 300hp easy. I made 292 with just a TBE, intake, MBC, and tune on a DynoDynamics on 93 octane. Thats close to 312 on a Dynojet.
Old Sep 12, 2007 | 12:43 AM
Celica2EVO's Avatar
yea the fuel pump is my 3rd thing to do! are cam gears wrth it or no when i so the shafts?
Old Sep 12, 2007 | 01:25 AM
tripperfx3's Avatar
Its good for fine tuning, but not really needed.
Old Sep 12, 2007 | 01:43 AM
Celica2EVO's Avatar
Here is my revised set-up, in order:
Hallman Pro RX MBC
K&N Filter and Adapter
Walbro 255 Fuel Pump
ECU Flash Tools
02 Housing
BR 3" TBE
GSC 272 Cams
APR Headstuds
Look like everything I need to get mid-low 12s? I dont want to drop abunch of money into it, but I want to break the 300 whp mark, and be in the 12s!
Old Sep 12, 2007 | 02:07 AM
TeKiZeRo's Avatar
Dejon tool or Hallman.
CmakEVOX
For Sale - Wheels / Tires
Mar 12, 2014 05:48 AM
jameswwt
Mar 5, 2013 11:13 AM
MitsuOZ
13
Aug 25, 2009 07:21 PM
Usedcarfinders
For Sale - Cars For Sale
Aug 22, 2008 09:57 AM
