Tightening spark plugs by hand...
Old Sep 13, 2007 | 02:53 PM
bluebanana23's Avatar
By hand, how do you know when to stop? I tightened using only the socket until it stopped and then attached the rachet and turned it very gently until it stopped...Too frugal to buy a torque wrench!
Old Sep 13, 2007 | 03:29 PM
Joshs EVO's Avatar
um you don't need a torque wrench, just aspark plug socket and en extension and your good. Tight but not too tight you break it.
Old Sep 13, 2007 | 03:31 PM
meckert's Avatar
snug and a qtr turn
Old Sep 13, 2007 | 03:34 PM
mifesto's Avatar
turn it w/ a simple wrench until it stops... then turn a pinch more .. done.
Old Sep 13, 2007 | 04:15 PM
dbsears's Avatar
When you hear the porcelin crack back off 1/4 turn and your good...j/k . Usually just get them all about the same and snug will work...kinda like sticking an oil filter on....once it gets a tad hard to turn then add about a 1/4 to 1/2 turn and should be good.
Old Sep 13, 2007 | 05:05 PM
nothere's Avatar
the little diagram indicates a 1/16 turn past snug when you have sloped washers.
and something like a half turn when the washer is flat.
Old Sep 13, 2007 | 05:10 PM
Evoryder's Avatar
torque wrench = $20
Spark plug = 19ftlbs(what I use) believe specified is 17ftlbs
hand tighten = 2 finger special
Old Sep 13, 2007 | 05:16 PM
skold's Avatar
3 bhaawhaps of a cordless impact thats our lexus torque spec at work.
Old Sep 13, 2007 | 05:25 PM
Curt@MrLed's Avatar
Former Vendor
i turn till the i feel the washer crush, and then go 1/4 turn.. i use a 6 inch 3/8 ratchet grasping it halfway..
why did i just type that.. if you cant figure out how to tighten plugs, get a mechanic or buy a torque wrench..
Old Sep 13, 2007 | 09:31 PM
Aby@MIL.SPEC's Avatar
buy a torque wrench, you will use it elsewhere...get a beam unit from craftsman for $20-
buy anti-sieze, nickel based, use a "grain of rice" worth on the threads closer to the tip.
when torqueing new plugs, tighten to 15 ft/lbs, baack off 1/2 turn, tighten to 15 ft/lbs, back off 1/2 turn, tighten to 15-17 ft/lbs.
you always need to seat the crush washer of spark plugs in a high power application, if not, you'll find some loose plugs down the road.
oftheheavens
Nov 29, 2010 10:04 AM
$MIVEC$
Jul 21, 2008 08:41 AM
ODUB
Apr 5, 2007 08:05 PM
ralliart 04
Apr 8, 2006 11:44 AM
Monkey
Sep 13, 2005 08:41 PM
