Car won't boost at all...help
Old Sep 14, 2007 | 02:37 PM
binh's Avatar
I was doing partial throttle today and it was boosting about 10psi when I heard a small pop.
I thought that maybe I blew a IC pipe but I checked them all and they are all secure (also have tbolt clamps on everything).
So I thought that since I was running 28+ on my stock turbo that maybe the turbo let go. I took off the intake and spun the turbo and checked for shaft play. Well it spins freely and there is no shaft play.
The car is on the aem ems with map sensor.
The car idles perfect. There is no white smoke or anything odd.
I checked any vacuum lines I could find to see if something blew off but I couldn't find anything.
The car will NOT boost at all. Not even 1 psi. The boost gauge won't go over 0 and it feels like I'm driving a honda civic.
Old Sep 14, 2007 | 02:38 PM
Evoryder's Avatar
you boost leak tested right?
Old Sep 14, 2007 | 02:39 PM
bmguser's Avatar
hole in the manifold or ic??
Old Sep 14, 2007 | 02:40 PM
bluebyu36's Avatar
need to do a pressure test
Old Sep 14, 2007 | 02:42 PM
binh's Avatar
No I haven't done it yet. It happened on the way to work so I didn't have time to test it.
I just figured if it was any kind of leak the car would still boost somewhat.
It doesn't boost AT ALL.
I've blown a hole in a IC before and the turbo will still boost.
Old Sep 14, 2007 | 02:44 PM
binh's Avatar
Stock manifold.
Turbo would still boost with a hole in the IC.
Old Sep 14, 2007 | 03:00 PM
Evoryder's Avatar
if you something piereced your turbo like my old car you wont boost at all...i had no idea i had a hole in my turbo till i pressurized the system...trust me, the leak will be SCREAMING at you...i had a hole in my intercooler and couldn't pressurize pass 4psi...
Old Sep 14, 2007 | 03:01 PM
binh's Avatar
Hole in your turbo? Can you clarify what you mean so it can help me troubleshoot.
Old Sep 14, 2007 | 03:15 PM
Evoryder's Avatar
a rock or bolt punctured my turbo on my 1.8T...could hear a loud hisss...no power(obviously) pressurize the system and lets quit guessing. Good luck
Old Sep 14, 2007 | 05:39 PM
binh's Avatar
Took the intake off and started the car and the turbo was spinning happily.
Took off the bumper and to my relief saw that the IC coupler had a tear the size of china in it. The tbolt dug into it and started a tear and I guess the 30lbs of boost did it dirty!
Sorry for wasting all your time.
Stock turbo for life!
Old Sep 14, 2007 | 06:12 PM
Evoryder's Avatar
what a waste lol ...
zac-mac
May 1, 2014 01:11 PM
black_beauty
48
Mar 19, 2013 08:11 AM
FlaEvolution
May 26, 2012 08:58 PM
partyboy1122
13
Jul 28, 2009 02:11 PM
Slo_crx1
10
Nov 6, 2007 09:24 PM
