What CAM for a 2.3L with a 50Trim? Experts weigh in
Old Sep 26, 2007 | 08:12 AM
SmokinJoe's Avatar
Yes.. I searched
I'm looking for some technical points here to help with the mid and top range. The motor is a 2.3L with a VIP 50trim. I have no plans of changing to a BB turbo at this time. The car is dropping off HP after 6K and you can feel the delay in the upper 6's. The motor has GSC 272s, no cam gears.
The boost is very modest at 22.
I'd like to keep the low end fairly stable and have a good idle.
Would cam gears be the best choice with the GSCs - or a new set of cams? Trying to cap this mod at $500.
... here is the car
http://i46.photobucket.com/albums/f1...1/DSC01076.jpg
Old Sep 26, 2007 | 08:31 AM
Wazvette's Avatar
The BR272 cams would definately help your top end...and the loop is not that bad also...what you need is beefier cams than what you got right now....JUNs are great also but loopier according to some people.
Old Sep 26, 2007 | 08:47 AM
SmokinU's Avatar
Yes a set of cam gears that are degreed in can make a good bit of difference. I tun +2 on intake and -1 on the exhaust. It was worth about 25awhp and extended my power band another 250rpms
Old Sep 26, 2007 | 10:01 AM
deadbeatrec's Avatar
Originally Posted by SmokinJoe
Yes.. I searched
... here is the car
u made more power with your ATP 3037s.
Old Sep 26, 2007 | 10:06 AM
well i would say the buschur 272 custom grind cams. JUN's are like $1000.
Old Sep 26, 2007 | 10:13 AM
Exciting News's Avatar
The GSC S1s seem to have made inroads and may be ideal. Since you have a stroker you may even go to S2s with success. I don't know much about the Buschur 272s other than their meant to be paired with GT35R sized turbos. The fact that you have a stroker and are moving more air may offset this. So, S2s or BF272s. As always, contacting the respective shop for advice is a good idea.
In any event, get rid of those GSC 272s. I think they're dated and nothing special.
Old Sep 26, 2007 | 10:39 AM
SmokinJoe's Avatar
I originally thought the restriction could be the 50trim - but I'm now more inclined to think its the outdated cams. And, at 22psi, the T3/T04E isnt beyond its range. The IC is a BR-Race.
The restriction is in the valves and timing. I suppose the gears would be the cheapest option. 25whp would be more than ideal.
But the cam choice seems to be newer S series or BR272s.
Old Sep 26, 2007 | 10:56 AM
DS-03evo's Avatar
I am going to get my VIP 50 trim along with a 2.3 tuned tomorrow.
I have weak sauce for cams though 264/272. So well see what happens...
How in comparison is that dynomight to a dynojet?
Old Sep 26, 2007 | 11:06 AM
Very similar.
Old Sep 26, 2007 | 11:07 AM
version 2 beta's Avatar
the restriction is the 50trim. cams will give you a little bit more power up top but will not change the fall off of the power after 6k.
Gears would be a minimal change in power. A custom set of cams with stock gears again will make a small change in your power drop off.
Look no further than your turbo for a larger power band.
Old Sep 26, 2007 | 11:12 AM
scheides's Avatar
EvoM Moderator
Have you done anything with the TB/intake manifold yet? Port those out before you put in bigger cams!
If you do go with some beefier stix, I would say go with the buschur BF272's.
Old Sep 26, 2007 | 12:13 PM
SmokinJoe's Avatar
The TB and mani are stock, but I think what we are seeing in the graph is a pretty big flow restriction.
I thought it could be the 50trim, but at 22psi, its not overstressed. And is within its range.
No other cams post the best mid/upper numbers besides the BR and GSC S series for the 8s?
Old Sep 26, 2007 | 12:20 PM
Rez90's Avatar
HKS 280s
Old Sep 26, 2007 | 12:45 PM
JPSR20DET's Avatar
I would get cam gears and dyno tuned.. then bigger TB and 22,5 lbs that would get you 400whp flat to 6700-800 rpm aprox.
