3rd to 4th problems????
Old Sep 26, 2007 | 04:41 PM
gen3eclipsegt's Avatar
Question 3rd to 4th problems????
soo went to the track every time i go for a launch everything is good till i go from 3rd to 4th the car acts like it dosnt wanna go in takes a few times any one else have that problem but if i do a highway pull i dont have that problem
Old Sep 26, 2007 | 04:51 PM
TTP Engineering's Avatar
Witch stage 2 clutch do you have?
Old Sep 26, 2007 | 05:00 PM
dunno ha i bought the car used from a dealer with the clutch and flywheel in i was told it was a twin disk i took it down to cbrd to get some work done and they said it felt like it could be a act or a no name clutch ... they didnt think it was a exeddy but it really grabs also alot of clutch chatter!!!
Old Sep 26, 2007 | 05:08 PM
Redline-Z's Avatar
Veteran: Air Force
Grabs hard and has alot of chatter, sounds like an Exedy twin to me
kikazzdrummer88's Avatar
i would be carefull with that , mine was doing that as well but it was 3rd instead of 4th and i ended up destroying my 3rd gear but now i got a new ACT HDSS clutch and hopefully i wont have this happening again ... good luck with the problem
Old Sep 26, 2007 | 05:13 PM
hopefully its a exeddy haha ... stupid ? but gonna ask anyway but is it bad for the clutch to chatter because when the a/c is on its 4x louder, try to avoid on using the ac because of it anyway that 3rd to 4th really hurts my 1/4 time iwent to the track last week hit a 13.7 with 15psi boost controller was messed up fixed now should of been at 22.5 psi and hitting 4th so deft should be in the 12's
Old Sep 26, 2007 | 07:04 PM
dxbevo9's Avatar
i think your 4th gear selector is gone..i had the same problem with my exedy stg1 organic clutch...took the gear box apart to find that the clutch along with some hard driving on my side has caused damage to the selectors..
goodluck
