Transfer Case?
Old Sep 30, 2007 | 07:44 PM
Cinci Turbo IX's Avatar
Transfer Case?
I just read through two different "How to's" on installing a clutch for my Evo. With the ACD I understand that I do not have to remove the transfer case. However, will I need to order more Mitsubishi GL5 LSD EVO Gear Oil Diaqueen for the transfer case?
I have already ordered both transmission fluid and the Diamond ATF SP III for the bleeding of the ACD.
Once again, my question is whether or not I need to order gear oil for the transfer case.
Old Oct 1, 2007 | 09:23 AM
Bump for an answer please!
Old Oct 1, 2007 | 09:32 AM
psphinx81's Avatar
unless u dont have any yes u will have to.. ull have to drain the transfer case of its fluid when swapping the clutch
Old Oct 1, 2007 | 09:50 AM
Boltz.'s Avatar
FCOTM Winner
How do you plan on bleeding the ACD? That takes a 3k+ MUT tool
Old Oct 1, 2007 | 03:02 PM
I was unaware of that. I read the "How to" and this is what I found........
"to bleed the ACD make sure you top of the fluid for the ACD its ATF III rated fluid. Get someone in the car and someone under the car - the person under the car needs to break loose the bleeder screw on the ACD (10mm wrench) and use a piece of plastic line (rubber tubing of some sort) for spotting bubbles. Get the person in the car to turn the key to the on postion but not start the car and have them press the gas pedal to the floor. This will turn the ACD pump on for 5 seconds. Repeat this process until there are no more air bubbles coming from the bleeder screw. close it and your done!"
If this is incorrect, please let me know. I found this in the Evo "How to" section. Is there any alternative method aside from using the 3k MUT tool. I'm sure that a lot of people have installed clutches on Evo's with ACD without using this tool.
Thanks
Old Oct 1, 2007 | 05:00 PM
apagan01's Avatar
Thanks
the dealer is replacing my acd pump right now,,, i will ask the mechanic how he did it,,,,, cant get a better answer than what you get from a mitsu mecanic,,,,, PM me to remind me,,, and ill give you what he did / said
EvoVIII :D
Aug 14, 2016 07:28 AM
Jeepyedo
Jun 28, 2016 10:57 PM
Kerr Lai
Apr 14, 2016 07:14 PM
Autoxevo
May 5, 2015 12:15 PM
krazykorean84
Nov 30, 2008 07:21 PM
