Buzzing noise
Old Oct 2, 2007 | 06:34 PM
evo585's Avatar
Buzzing noise
I have a buzzing noise under my car in the back center. It doesn't seem to be the exhaust because I moved it around and the noise didn't change. The noise is located approximately where the read diff is. Is it possible something in the gas tank could make that noise. I don't know what else it could be. Any ideas?
Old Oct 2, 2007 | 06:39 PM
bluebanana23's Avatar
Bumble Bee? Do you have a walbro installed?
Old Oct 4, 2007 | 02:40 AM
evo585's Avatar
I bought the car from a used car dealer and they didn't know what it had. So Im not sure. If I open up the fuel tank to look at the pump can you tell the diff between a stock pump and walbro?
Old Oct 4, 2007 | 04:10 AM
mac74's Avatar
most likley its a the fuel pump. wally for sure if its buzzing, a way to check is put the turn signal on and if the nosie changes as the signal blinks then its the pump..
