A/F Ring Options?
Old Oct 4, 2007 | 02:00 PM
MikSchultzy's Avatar
A/F Ring Options?
Been searching for some A/F rings for my Evo 8, haven't found any anywhere. Needing some because I feel that the stock bottom end is OK for ~400whp, and I don't feel the forged piston/rings are worthwhile. Ontop of that, OE rings are ~175 - at that point, I'd be better off shelling the extra 100 or so for new pistons.
Old Oct 4, 2007 | 04:49 PM
RoadSpike's Avatar
I must admit a true bit of confusion here..
How do rings make a engine block more reliable when truely its the rods that break/bend and the pistons that crack at higher horsepower levels.
Old Oct 4, 2007 | 05:58 PM
I've seen rings cause it from flex too/wear too, gouging cyls. Mostly on smaller engines though.
Old Oct 4, 2007 | 07:20 PM
RoadSpike's Avatar
Never seen it happen on one of these cars though I have seen pistons crack, in half pins go through the side of the motor, and some of the coolest carnage was when the rod smacks into the balance shaft..
If your going to tear your motor apart you may as well do it once and do it right imho drop in pistons and rods.
Old Oct 4, 2007 | 07:37 PM
Money is an issue, else I would have already.
And it's not that I didn't plan enough, it's that other issues came up. Life happens. (more commonly known as "**** happens")
But that doesn't answer my question of weither or not there are A/F rings.
CJBarker2
Lancer Tranny/Drivetrain Tech
Dec 22, 2016 07:24 PM
LancerShop.com
Lancer Vendor Classifieds
Dec 21, 2016 06:39 PM
wreckleford
Apr 19, 2016 08:00 AM
slostjoe
Nov 12, 2015 01:59 PM
08bluegts1
Lancer Aftermarket Forced Induction Tech
Jun 11, 2011 04:01 PM
