Which UICP works with ARC induction box?
Old Oct 12, 2007 | 06:33 AM
Evo Tengoku's Avatar
Anyone know if the ARC is quieter than the injen intake? I've got the injen now and it's getting annoying...
Old Oct 12, 2007 | 08:13 AM
nick@maxum-tec's Avatar
Originally Posted by Chukee_R
Which Nisei UICP has the mount for the BOV on the upperside? (NM found the link)
Now I want to know which MAF hard pipe will work with the ARC box.
The Nisei Engineering UICP's w/HKS BOV usually come with the valves mounted on the top. In my other post I mentioned that Nisei locates the valve per customer request. You might want to read my other post and take advantage of the timing. Check it out if you get a chance.
Old Oct 12, 2007 | 04:08 PM
Chukee_R's Avatar
Anyone have some confirmed MAF hard-pipe fitments w/ ARC Induction Box? I really wouldn't want to switch back to the plastic stock MAF pipe.
Old Oct 12, 2007 | 04:16 PM
cpoevo's Avatar
I have the Dejon hard pipe and I use it with the stock intake box, so it should work with the ARC intake.
Old Oct 12, 2007 | 06:05 PM
Erik@MIL.SPEC's Avatar
I personally think the Samco would be the best option for the ARC box. It will reject heat a lot better than a metal pipe.
Old Oct 12, 2007 | 07:32 PM
Chukee_R's Avatar
I'm just worried that a Samco hose would collapse under high boost.
Old Oct 12, 2007 | 07:37 PM
How would it collapse when it's under vacuum? Only things downline from the compressor wheel are under boost AFAIK.
Old Oct 13, 2007 | 04:42 AM
Chukee_R's Avatar
Uhhh, how wouldn't it?
Air gets sucked in...like a vacuum. Everything down the line after the turbo would expand.
Old Oct 13, 2007 | 06:09 AM
And since the Samco hose is BEFORE the turbo, my original point stands. No?
Old Oct 13, 2007 | 07:07 AM
krazirob's Avatar
I just played it safe and got ARC all the way around......question though. does the box sit that far up out of the engine bay like the pic above??? i dont think i will like the box sitting so far up like that
Old Oct 13, 2007 | 07:42 AM
krazirob's Avatar
well heck anyone on here have the ARC setup??? any bung needed for the stock BOV???
and damm that samco pipe on the cold side is PRICY......lol
Old Oct 13, 2007 | 07:44 AM
BlueDemon's Avatar
LMAO
Sorry for laughing dude but how the heck is going to collapse under vaccum, it is not like it is sealed up like a ballon. It's function is to redirect air into the turbo, you are talking like if there's a plate inside the thing that opens and closes .
Old Oct 13, 2007 | 08:07 AM
Chukee_R's Avatar
Originally Posted by BlueDemon
LMAO
Wow you guys are fricken intelligent...TURBOS SUCK AIR IN! I never said I was worried about it collapsing under vacuum. I said under boost.
I guess you've never heard of people with CAI having problems with the piping couplers collapsing and restricting air under boost. The Samco hose is made from silicon which to my knowledge is somewhat flexible. So add some heat from the engine and it would become even more flexible. That is the whole reason behind hard pipes. So things don't expand / collapse. So go LMAO back under your rock.
Old Oct 13, 2007 | 08:39 PM
trinydex's Avatar
Originally Posted by EVOSlayer
Nisei Engineering has it here is a Link & a couple of pix as well.
http://www.nisei-evo.com/forum/viewtopic.php?t=33
troof. and the hump hose goes between the uicp and the year pipe.
Old Oct 13, 2007 | 08:40 PM
trinydex's Avatar
if you're installing silicon hoses so that they're acting as pipe and not sealant... you're doing things wrong.
oh wait... that's how the samco hoses are... honestly though... it's probably not a problem.
they have that induction pipe and it doesn't collapse...
