Which stainless clutch line did you go with?
Old Oct 11, 2007 | 03:24 PM
06MRV8Killer's Avatar
Does the ss clutch ine really make a difference? What role does the "pill' play in the drive train?
Old Oct 11, 2007 | 03:26 PM
Z1 Performance's Avatar
it is literally a night and day difference in clutch feel
the pill controls (or limits) the amount of movement of the slave. I personally like how it is better with the pill in, but its all personal preference
Old Oct 11, 2007 | 03:28 PM
grenade's Avatar
Originally Posted by Z1 Performance
I'm sorry I gotta laugh at this
every stainless line has teflon in it....that's what the fluid flows through If it flowed through the stainless braid, it would all leak out
As long as it fits, it will work....hardware being included is a nice touch too. A must have for any Evo I think
http://www.z1auto.com/prodmore.asp?m...ine&prodid=488
for those interested ^
While not 100% true, your mostly correct. any -3 AN line has teflon. There are a wide arange of -4 AN to -26 AN That are rubber.
I went with Russell. I got in from work, and fast.
Old Oct 11, 2007 | 03:30 PM
Night and day difference in what way? i have been thinking abou tdoing it bc of my twin disk that i have installed.....
What kind of "movement" or fel does the pill play in the drivetrain I dont quite understand its function if someone can explain. Thanks in advance
Old Oct 11, 2007 | 04:26 PM
wshihdnevo's Avatar
lancershop or RRE IMHO
Old Oct 11, 2007 | 04:39 PM
mrich82's Avatar
When I did the clutch line and pill removal (stock clutch at the time) I noticed that the clutch pedal feel was more consistent and didn't want to slip as much. Its hard to explain really, but if you do it you will notice the difference for sure.
Old Oct 11, 2007 | 04:43 PM
CrackerJackToy's Avatar
I think im going to just have the stainless pill put in, and at a later date do the pill removal. Figure ill see what just the line will do for me.
Old Oct 11, 2007 | 04:45 PM
wshihdnevo's Avatar
Remove the pill before you get the SS clutch line. You will be able to tell a bigger difference removing the pill, than just doing the line and its easy, there are instructions on how to do it at evomoto.com
Old Oct 11, 2007 | 04:49 PM
coo thanks, now another Q is which type of ss line to get.
Old Oct 11, 2007 | 04:52 PM
JordanS4's Avatar
Originally Posted by esdot24
Sorry for the unrelated question but what exactly does the restrictor pill do?
I thought that it causes your clutch to burn if you dont come off at high RPM properly, but I could be wrong. If I'm right that would mean that you would be able to do some sick launches with the pill removed. Anyone with the knowledge please answer.
The restrictor pill slips the clutch for you. Thats why when people slip on the launch they burn the clutch up. Releasing the pedal as quickly as possible without dropping it = 1.5x's on the stock clutch, tires, and lines.
Old Oct 11, 2007 | 05:12 PM
Originally Posted by JordanS4
" Releasing the pedal as quickly as possible without dropping it = 1.5x's on the stock clutch, tires, and lines."
What exactly do you mean by this?? Is it a good idea to remove the pill or keep it there or does thay depend on your driving style...?
Old Oct 15, 2007 | 12:41 PM
bump
Old Oct 15, 2007 | 01:57 PM
Danny23's Avatar
Remove the pill from the slave cylinder,and use a BR SS line. You will love it.
Old Oct 15, 2007 | 02:12 PM
I understand the "slip" part but i dont quite follow the other part "Releasing the pedal as quickly as possible without dropping it = 1.5x's on the stock clutch, tires, and lines"
Old Oct 15, 2007 | 02:28 PM
RyuEvoIX's Avatar
He is referring to releasing the clutch pedal and engaging the clutch as quickly as you can without "DUMPING the clutch" = a very good launch without breaking your transmission or transfer case.
