help on engine build
Old Oct 16, 2007 | 01:37 PM
Evo818's Avatar
im looking to run a gt3582r or a gt37 i want to build block first but not sure if i should just upgrade my rods adn pistons with out going to a stroker or not i would like to do a 2.4 stroker but not sure if i should... if i went 2.4 stroker will it be safe to run the gt35 or gt37 on street adn track on weekends.... and if i should just upgrader piston and rods with out going to a stroker what company are good with rods and pistons thanks
Old Oct 17, 2007 | 11:25 PM
evo L's Avatar
yes a stroked motor will be fine with a 35 or 37, you can make a safe 350-400whp on the stock block though, are you planning for more than that?
Old Oct 18, 2007 | 08:24 AM
haseeb's Avatar
for just the pistons and rods ,go wid wiesco pistons and oliver rods and if u wana doo stroker get jam (jackson auto machine ) stroker kit .
ill recommend u to go gt3582 rather than gt37 as gt37 will be having a bit of lag even on a stroker .
Old Oct 18, 2007 | 08:46 AM
Cinci Turbo IX's Avatar
stick with the gt35... like haseeb said.. gt37's will have boost lag
Old Oct 18, 2007 | 12:29 PM
CO_VR4's Avatar
Whether you want a stroker or a built 2.0L would depend on your intended use. Almost all of the top drag cars are 2.0L. Strokers provide increased low end, but sacrifice high end RPMs.
There are plenty of 37R cars that are running on the street. It depends on your tolerance for when boost comes "on the curve". FP is coming out with a 37RHTA version that will have much stronger mid-range, if the 35RHTA maps are any reasonable comparison.
On the other hand, there are now a number of stock blocks with Evo Greens that are making well over 400 HP and huge torque numbers (470+) that might be a very nice option for you as well.
I'd suggest driving cars equipped with the various turbos you're considering before you spend big $ and then decide you were actually looking for a different performance envelope.
Old Oct 19, 2007 | 05:38 AM
Evo_7's Avatar
I think you should go with a 35r kit and built your block.(Get Oliver Rods or Carrillo Rods and CP,Ross or JE pistons).
Once you get bored of your 35r than shift to a 37r.
