Evo 9 turbo install kit for Evo 8
If you purchase it from mitsubishi, it's actually cheaper:
1 - 1515A057 Fitting, Air Output $37.91
1 - MR281085 Gasket, Air Output $2.74
1 - 1310A171 Pipe, Water Return $8.38
1 - 1310A248 Pipe, Water Feed $8.38
1 - 1225A042 Tube, Oil Feed $7.89
2 - MF660063 crush washer @ $0.79
2 - MF660064 crush washer @ $0.93
4 - MF660065 crush washer @ $0.57
1 - MN156738 gasket for the oil return tube on the bottom of the turbo $1.34
Hmm not sure here but I got the complete 9 turbo set up with exhaust manifold and it was a direct bolt on. Had to use the pressure side pipe off the 9 turbo but that was the only thing I had to change. Lucky IDK but I haven't had an issue with it as of yet and there were no clearance problems. FWIW I reused all the gaskets also no issues or leaks.
I've heard of people manipulating the oil/coolant lines of there evo 8 turbo but the j-tube must be changed. It wll hit the starter and cause a fire under your hood.
Good luck.
Jason
Good luck.
Jason
Below is the list of hardware I purchased from Mentor Mitsu when I installed my JDM 9 RS turbo. I bought a used exhaust manifold and O2 housing and had them JET-HOT® coated before installing the turbo. Also, note that I replaced all studs (PITA) w/bolts and I bought new nuts/washers since the ones on the car were rusty.
Bolts, nuts and washers
4 MN119783 Bolt,T/C 10x35
4 MD062961 Bolt,O2 10x31
1 MD727552 Bolt,O2 10x19
2 MR224500 Nut,EM 10
7 MR212302 Nut,EM 8
11 MD132933 Washer,EM 10
7 MD041192 Washer,EM 8
Lines
1 1225A042 Tube,t/c Oil fe
1 1310A248 Pipe,t/c water fe
1 1310A171 Pipe,t/c water re
Gaskets and seals
1 MR323654 Gasket,exhaust manifold
1 1515A184 Gasket,t/c inlet
1 MR299686 Gasket,t/c outlet
1 MR258477 Gasket,t/c oil re turbo
1 1226A002 Gasket,t/c oil re pan
2 MF660063 crush washer for oil line at cylinder head
2 MF660064 Gasket,t/c oil fe seal
4 MF660065 Gasket,cooling wa
1 MR450703 Seal,O2 to exhaust
1 MR281085 Gasket,J-pipe
Other parts
1 1515A057 9 J-pipe (lots of threads on why this is needed)
7 MR212302 Nut,EM 8
Lines
Gaskets and seals
Other parts
Yup all that needs to be replaced is the J Pipe the VIII's lines can be made to work without issue.
Buschur and FP both sell a nice kit though. I bought the buschur kit when I did my 20g set up back in the day
Check Ebay. This auction here has new banjo bolts as well, $62 shipped.
http://cgi.ebay.com/ebaymotors/Turbo...#ht_1529wt_939
