Transfercase Oil
Old Oct 19, 2007 | 04:14 PM
vxevolutionxv's Avatar
Transfercase Oil
Hey guys whats up, i just replaced my clutch and i got everything back together but in the owners manual it says to use "mitsubishi limited slip differential oil or equivalent" for the transfercase oil. I was wondering if Castrol SAF-XLS would be a good substitute for the mitsu oil? If not could you guys give me a good equivalent to the mitsu LSD Oil?
if i could get osme quick responce that would be great i gotta get it running so i can get to work on sunday.
~Chris
Old Oct 19, 2007 | 04:28 PM
jenx1976's Avatar
DONT put anything in there other than what mitsubishi specifies.....my TC has the "death whine" because i used the wrong fluid!!!!, just go to the dealer and MAKE SURE u get the LSD GEAR OIL.....or go to lancershop.com and order it.....there are other shops that sells them too depending on where u from....
Mitsu3's Avatar
use the mitsu stuff only....GL5 SAE90 OEM Diaqueen Mitsubishi fluid its for the transfer case and rear diff
http://lancershop.com/customer/produ...&cat=15&page=1
Old Oct 19, 2007 | 04:40 PM
ok, thanks alot for the input guys. illpick it up frommitsu tomorrow.
