ix turbo install w/ out tune
Ive searched on here quite a bit trying to find out if it's a bad idea to cruise around with a ix turbo on my VIII until i get a retune for it. Ive got a custom tune for the stock 9.8 turbo, but im getting ready to swap it out with the ix turbo that i just bought. I guess as long as i stay out of boost i will be fine? Thanks guys.
The IX turbo isn't any bigger than the VIII turbo/compressor wheels. Just bigger housings. It's impossible for the car to run lean over the VIII turbo! This IX turbo hype like it's actually a valid upgrade is annoying..
-M
your ECU will do its best to do what it can to keep you correct but, to get the most gains and to be safe get a tune!
ANY time you change air/fuel OR turbos you should get a tune.
Just my 2 cents..
-M
Guys, i know its an upgrade. I know its not a huge upgrade, but it is a proven upgrade. I just needed to know if whether to stay outta boost until i get it retuned, which i know it will need. Sorry BOOSTEZ but you are completely wrong, the ix turbo yeilds higher hp than the viii. Common sense becasue it flows more due to the bigger compressor housing and hotside, even though the wheel is the same.
If, for example, you put on a 35r or green turbo, THEN I'd tell you to lay off the throttle because it's pushing enough airflow at a certain psi to cause the motor to go lean and cause detonation. Get what I'm saying??
-M
