vibration problem
Old Oct 22, 2007 | 11:00 PM
raidokoiv's Avatar
vibration problem
ok this is mitsu forum but maybe someone knows why my 04 STI vibration when i shift the gear down.whats the problem?propeller shaft bushing or something?or maybe flywheel or clutch.flywheel is stock ,clutch is exedy racing
Old Nov 11, 2007 | 05:24 PM
alkupik's Avatar
It could be that your clutch wasn't installed correctly. I would start with that since you have changed it. It's a good possibility that it's the culprit.
Old Nov 11, 2007 | 06:23 PM
timmiii's Avatar
The exedy is grabby clutch, it could be that you're just dropping it and not letting it out smoothly. Also you'll need to rev match.
