What to do next???
Old Oct 26, 2007 | 08:10 AM
PATRICK B.'s Avatar
What to do next???
Well had the car on the dyno again last night to double check the boost pressure and make sure the car is right for TNT @ Sac Raceway tonight.
Hope to get into the 10's w/ some decent track prep on the Advans.
We got the car up to 34 psi but backed it down a full turn on the Hallman to be safe.
The IDC was 100% for a bit longer than Sean our tuner cared for.
Now my ? is it put down 520 which is on par with what it did before......but should i try and make more power by putting another FP in or should i try and max out the HP level to get the ET's down w/ some "real" tires ie. slicks or dot qtp's etc.
Also what could i expect if i did decide to do some work to the head. I'd rather not at this point but curious to hear what others think.
How far will the 35R go w/ the stock head and enough fuel for 40ish psi???
Let's hear your opinions.
