stock turbo seems laggy
Old Oct 27, 2007 | 06:08 PM
redevo8u's Avatar
with stock intercooler and pipes my car hit 20psi at about 3400rpms but after intercooler, uicp and licp it seems to spool at around 4200. does it really take that long to build boost in a larger intercooler or does anyone think that i have a boost leak?
Old Oct 27, 2007 | 06:17 PM
kreionic's Avatar
Yeah I would say a definite boost leak. My spool didn't change at all with a 3.5" ic
Old Oct 27, 2007 | 06:20 PM
TouringBubble's Avatar
I agree. It's either a horrible core or a leak. I just got done with some logs and hit 24 psi at 3200 RPM ... I've got the 3.5" eBay IC.
Old Oct 27, 2007 | 06:21 PM
Slo_crx1's Avatar
It also depends on the pressure drop of the new IC and piping. Larger piping and fmic will have a slight loss over the stock system due to larger spaces to fill with air, but unless it's a real cheap setup I couldn't see an 800 rpm difference.
Old Oct 27, 2007 | 06:24 PM
redevo8u's Avatar
not a cheap setup all buschur, ill go check for a boost leak. any one have a link for an easy way to check for a leak
Old Oct 27, 2007 | 06:29 PM
bluebyu36's Avatar
something is def wrong you have a leak..or something is wrong with your wga
Old Oct 27, 2007 | 06:31 PM
redevo8u's Avatar
i found a link for a tester so im gonna go test it and let everyone know what i found
http://www.vfaq.com/mods/ICtester.html
Old Oct 27, 2007 | 06:43 PM
Slo_crx1's Avatar
Yeah, the Buschur setup is very good. Easiest way to check is leave the car off and take an old coupler and stick a schrader valve in it. Use the valve to pressurize the piping from an air compressor, and then spray soapy water around all the piping and couplers to look for leaks...if it leaks, you'll see bubbles.
Old Oct 27, 2007 | 07:00 PM
BoOsTinGEVO190's Avatar
What fmic do u have and piping ?
Old Oct 27, 2007 | 09:31 PM
jonjon0517's Avatar
like most ppl already stated check everything again and make sure its on tight.. looks like you have a boost leak..
Old Oct 28, 2007 | 05:52 PM
redevo8u's Avatar
buschur deluxe core and buschur piping
Old Oct 28, 2007 | 05:54 PM
redevo8u's Avatar
if i did this wouldn't it just leak out of the turbo inlet?
Old Oct 28, 2007 | 08:29 PM
Soon2BEVO's Avatar
Definitely a boost leak. I had that exact setup.
Old Oct 28, 2007 | 08:37 PM
Tpayne84's Avatar
i hit 24psi at 4200rpms.... but im on a 30r
you most likely have a leak somewhere in your IC pipings. double check all the couplings.
Old Oct 28, 2007 | 09:17 PM
mifesto's Avatar
although you do have a larger FMIC, your UICP and LICP reduced significant number of bends and shortened the path overall... your spooltime shouldnt be greatly affected in either direction
