HKS mivec cams
Old Dec 21, 2007 | 04:03 PM
Tarmacisback69's Avatar
i got hks mivecs with bpu and doin 363hp//363tq
the cams have no lope, and i had the belt problem it was squeeling. i changed my oil and it aparently went away i know its lubricated or sumthing.
Old Dec 21, 2007 | 04:11 PM
Show286's Avatar
What about when you come to a stop? Mine get really lopey for acouple seconds.
Old Dec 21, 2007 | 08:42 PM
Jeff_Jeske's Avatar
Who the hell cares about lope? If you want it dial the mivec map in for it.... if not tune it away.
Old Dec 21, 2007 | 09:05 PM
Show286's Avatar
Not me. I rather it sound stock. When it does get lopey thats when things start to shake and rattle..... Damn motor mount
Old Dec 22, 2007 | 05:48 AM
supersal's Avatar
I have both intake and exhaust HKS 272 cams on a IX...
Bang for the buck I say just the 272 Ex Cam + a 20G from Turbochargers dot com, or the Green if you can justify the $600 extra...
Otherwise just HKS 272 cams on a IX not worth much more than 10-15hP WITH GOOD MIDRANGE TORQUE!!!
Old Dec 22, 2007 | 02:19 PM
Jeff_Jeske's Avatar
I don't want to rip on the cams I simply haven't seen anyone in a cam'd 9 turn better traps than the stock cammed 9s. Maybe gains are mostly had on pump gas.
I'm sure there's something to be had I'm just not sure its worth the cost and trouble.
Old Dec 22, 2007 | 09:42 PM
boardride's Avatar
i like lope it sounds tough, but mine is not loping, i know a guy with cosworth cams and his lopes like crazy. oh well the power gains are good. car pulls much harder than before. driving my friends evo with basically the same mods as mine minus the cams feels much slower through out the power band.
Old Dec 23, 2007 | 07:41 AM
TEAM ACE's Avatar
i put in hks 272s and mine lopes real hard. but you gotta remember that with out the tune the car will keep trying to correct itsself
Old Dec 23, 2007 | 10:37 AM
SavEVOIX's Avatar
Bang for the buck they aren't worth the trouble unless you have a bigger than stock turbo. Average gains are 10-15whp. Expensive little buggers.
I think it would be better to upgrade the turbo before upgrading cams.
Power under the curve...
Old Dec 23, 2007 | 05:33 PM
evoguy333's Avatar
i have the gsc s1 cams and when first installed they sounded just like stock. then after changing the values at idle in the mivec map it sounds more like an 8 with cams now
Old Dec 23, 2007 | 05:45 PM
max2evoix's Avatar
cosis baby..
Old Dec 23, 2007 | 05:46 PM
OKIX's Avatar
i use to have the hks 272's for my ix, but recently switched to JUNs. If you want lope the JUNs give you all the lope you want. As for a back to back comparison test....my father and buschur racing did this exact comparison between the two cams. I will look for the link.
Old Dec 23, 2007 | 05:57 PM
evolved83's Avatar
how much were the jun cams?
Old Dec 23, 2007 | 06:13 PM
OKIX's Avatar
here is the link i was referring too.
https://www.evolutionm.net/forums/sh...d.php?t=303825
Old Dec 26, 2007 | 04:35 PM
EvilTechnology's Avatar
I'm the other of the 2 people in the US with JUN Mivecs. I have no lope except for a few seconds on cold start and once in a while when the idle drops down to 500 for a second (mine has always done this since I bought it new).
