Need EVO8 ECU PIN DIAGRAM, tried search
Old Jul 14, 2003 | 06:08 PM
IzenGreyEvo7's Avatar
Can anyone direct me to a photo, diagram, or previos post of the pin out info. I tried a search and I couldn't come across one. Thanks in advance.
Old Jul 14, 2003 | 06:11 PM
nastea's Avatar
http://www.roadraceengineering.com/e...-ecuwiring.htm
Old Jul 14, 2003 | 06:13 PM
THANK YOU!!! That helps immensely.
Old Jul 14, 2003 | 06:16 PM
nastea's Avatar
np
Old Jul 15, 2003 | 09:33 AM
MSP-EVO's Avatar
ECU Pinout
1 No. 1 Injector 14 No. 2 Injector
2 No. 3 Injector 15 No. 4 Injector
3 Fuel Pressure Solenoid 16
4 Idle Speed Control (ISC) Motor Coil (A1) 17 ISC Motor Coil (A2)
5 ISC Motor Coil (B1) 18 ISC Motor Coil (B2)
6 EGR Solenoid 19 Volume Air Flow Sensor Reset Signal
7 20
8 A/C 21 Cooling Fan Motor Relay (PWM Output)
9 Evaporate Emission Purge Solenoid 22 Fuel Pump Relay
10 Ignition Power Transistor (for cyl 1&4) 23 Ignition Power Transistor (for cyl 2&3)
11 Turbo Wastegate Solenoid 24 A/C
12 12V Switched Power Supply 25 12V Switched Power Supply
13 Chassis Ground 26 Chassis Ground
Pin Connection Pin Connection
31 A/C 39 Fuel Pump Relay (Additional pressure for higher loads)
32 A/C 40 Sensor Ground (IAT, Cam and Crank Angle Sensors)
33 Generator G Terminal 41 Generator FR terminal
34 42
35 Intercooler Sprayer 43 Clutch Position Switch (Input)
36 Check Engine Light (Service Engine Soon) 44 Intercooler Sprayer
37 Power Steering Pressure Switch (Input) 45 AC switch
38 MFI Relay (Power Supply) 46 Fuel Tank Level (Input)
51 Imobilizer ECU (Anti-Theft) 57 Intercooler Sprayer
52 58 Tach Signal (Output)
53 59
54 O2 Sensor Heater (rear) 60 O2 Sensor Heater (front)
55 EVAP Vent Solenoid Valve 61 Fuel Tank Differential Pressure Sensor
56 62 Data Link Connector
71 Starter Signal 82 Ignition
72 Intake Air Temp Sensor Signal 83 Coolant Temp Sensor Signal
73 Manifold Differential Pressure Sensor 84 Throttle Position Sensor Signal
74 Sub Fuel Level Sensor 85 Barometric Pressure Sensor Signal
75 O2 Sensor (rear) 86 Vehicle Speed Sensor Signal
76 O2 Sensor (front) 87
77 Fuel Temperature Sensor 88 Camshaft Position Sensor Signal
78 Knock Sensor 89 Crankshaft Position Sensor Signal
79 Data Link Connector 90 Volume Air Flow Sensor Signal
80 Backup Power Supply (12v Constant Power) 91 Intercooler Sprayer
81 5V Sensor Power Supply
(TPS, MDP, Baro, Fuel Tank Press Sensor) 92 Sensor Ground (O2 Sensors, Coolant Temp,
TPS, MDP, Fuel Tank Press Sensor)
Attached Thumbnails Need EVO8 ECU PIN DIAGRAM, tried search-ecu-harness-evo.gif
Old Sep 26, 2009 | 10:26 PM
TGC_QS's Avatar
so just to make this clear , pin # 62 orange wire right ? , and pin # 79 green white wire ,
these 2 are data link wires yes ?
Ferp
Jul 16, 2024 06:26 AM
1gcrazy
Jan 16, 2019 08:16 AM
elhalisf
Jun 15, 2013 06:10 AM
sponge bob
11
Feb 29, 2012 01:10 PM
Antilag
Jan 28, 2005 06:57 AM
