Evo 8 won't pass Emissions/smog test.
Old Nov 9, 2007 | 06:13 PM
ray3328's Avatar
change the plugs and clear the codes again...
Old Nov 9, 2007 | 09:03 PM
nx302stang's Avatar
Ill do that. If the plugs are good, I'm going to double check the plug gap. I don't remember what the gap should be, what do you guys recommend for 92 octane? The cars mods are on the original thread.
Old Nov 9, 2007 | 10:07 PM
G20's Avatar
G20
is the p0300 code came on while you were idle or driving normaly? Or when you drove it hard?
Old Nov 10, 2007 | 09:05 AM
nx302stang's Avatar
I cleared the ecu by disconnecting the battery overnight. Drove the car for about 30 miles normally and the CEL was off. When I got to the autoparts store to make sure that there are no codes stored on the ecu, but once I plugged the code reader to the car, the CEL turned back on.
Old Nov 10, 2007 | 08:23 PM
G20's Avatar
G20
i had similar problem and solve it by decreased some timings around the idle and low load area (500-3000 rpm and 30-80 load). You'll need ecuflash or some one know ecuflash and datalog to do it.
First, decrease about 3-5 timings to make sure it's actually solve your problem. If it is then go back and start decreasing 1 timing as a time until you find the minimal timings decreased that solve your problem. Usually, the timing was increase to make the cams idle better but for my case it thrown the p0300 occasionally when idle or driving normal.
Also, open the cam gear cover and make sure it's line up perfectly (the marks are centered). For my friend case, it was off a little and caused the p0300 on his.
I'm not sure it's the same for your problem but hope it help.
Old Nov 10, 2007 | 08:33 PM
dmit's Avatar
your goign to have to put t stock cat on, or delete to codes, but codes will not stay deleted foreer, so your better off putting the ctoc cat on fot the smog check, i had the same problem, i just put the cat on.
Old Nov 11, 2007 | 11:10 AM
ray3328's Avatar
You can't erase the codes by disconnecting the battery, just because the light for the code isn't on doesn't mean it isn't stored. You have to use the code reader to erase them. Put some new plugs and erase the codes and lets see what happens before you try something else.
Old Nov 11, 2007 | 07:43 PM
nx302stang's Avatar
Thanks guys! i'll troubleshoot some more when I get back from Vegas! i hope something works, cuz my friend cars tags are gonna expire 12/01/07!
Old Nov 17, 2007 | 05:08 PM
nx302stang's Avatar
I'll try this. All the codes are gone besides the Misfire code. I haven't driven the car hard or hit boost since the code popped up. Mitsu re-flashed the car with the "latest" flash for the car, but the code still pops up under idle. They also checked the plug gap, and the coils and they said everything was ok.
Old Nov 17, 2007 | 08:58 PM
RSGuy's Avatar
once you get the codes cleared, put the cat back on and get it tuned for E85.
Old Nov 17, 2007 | 09:06 PM
EvoDan2004's Avatar
Originally Posted by nx302stang
My friends evo 8 it throwing codes out. So it won't pass emissions testing in Oregon. It's Throwing the following codes:
P0172: System too rich, Bank 1
P0243: Turbocharger wastegate solenoid malfunction A
P0300: Random/Multiple cylinder Misfire Detected.
Any help to troubleshoot the problem will be greatly appreciated!
And my mods are: ETS 57 trim, LICP, UICP, MBC, TBE, DOWNPIPE, PLX Wideband, HKS Intake, 720 cc Injectors, 255 lph fuel pump, and custom re-flash.
i like how he said '' my friends evo8'' then he said HIS mod list is...... so whos car is it. its ok that your trowing codes bro. we all trow codes. no need to hide or be embarest about it. lol.
Old Nov 18, 2007 | 11:06 AM
nx302stang's Avatar
Lol it was my OLD car that I sold to him, and he's deployed so I'm fixing it for him. As far as the CEL turning on, it seems that it turns on at idle and normal driving. I still keep thinking it's my car since I did all the mods to it and I drive it more than I drive my RS. =)
Old Nov 18, 2007 | 11:08 AM
pog0's Avatar
Back to stock. Solves everything.
Old Nov 20, 2007 | 10:25 PM
tobz's Avatar
Trust me. Put the stock exhaust back on.
Buy a code clearer and clear the codes right before you give the emissions guy your car. It was what worked for me. I failed 8 times, 16 dyno test. Sucked. Passed finally.
Old Nov 21, 2007 | 08:34 AM
nx302stang's Avatar
I thought if you cleared the car before the test, it won't pass because it hasn't done it's readiness test yet.
