fuel pressure regulator?s
Old Nov 9, 2007 | 03:35 PM
wickedwhiteIX's Avatar
ok im upgrading my fuel system and i see they have the AFC neo computer and they also have fuel pressure reg kit by AMS i was thinking about getting the AFC neo, ams injectors and fuel rail, walbro 255 evo kit and just wondering if i need the fuel pressure reg also aany help is great thanks guys
Old Nov 9, 2007 | 03:39 PM
recompile's Avatar
What mods do you have already? The FPR isn't needed for a while, so if you don't already have a Walbro, then chances are you don't need the FPR.
You definitely don't need the Neo, your stock ECU has more features than any piggy back.
Post your mods and start doing more research as far as which supporting mods are needed for your goals... injectors are not needed until you move to a big turbo.
Old Nov 9, 2007 | 03:54 PM
i have not installed any thing yet but i have the fp green turbo,borla header gsc s1 cams ,aem cam gears, act clutch, AMS fmic, tanabi turbo back and injen intake... and im going to get the stock ecu programed i think or do you guys think ill need aem ems??? i have nothing for fuel yet tel me what i need
Old Nov 9, 2007 | 04:17 PM
sparky's Avatar
Get a Walbro 255 LPH fuel pump and a set of 750c.c. or 780c.c. injectors. Don't get the NEO or whatever it's called. No need for a standalone or a piggyback ECU either. Instead, just have your factory ECU flashed. Furthermore, with your mods there is no need for an adjustable fuel pressure regulator yet.
