hid adjustment
hid adjustment
what do you turn to adjust the height of the beam.
can someone post a pic of it also??
the beams are aimed to low.
also which way do you turn the screw? left or right?
thanx in advance.
thanx in advance.
i know about the dial in the interrior of the car. what iam talking about is that even if you put the dial on "0", the beam is still kinda low.
there is a way to manually change it so the beam aims a little bit further away.
you can do this in the headlight assembly area but i just dont know which screw to turn and where to turn.
i think all evo's beams are aimed too low.
