need help on cam install
Old Nov 18, 2007 | 02:16 PM
robjeff25's Avatar
I have searched all day and found a lot of threads expressing the problem that i am facing, but want to ask a question; i cannot break loose the 17mm exhaust cam bolt; i have an impact tool that i am using and that does not work; i have an extra set of hands and we cannot get the bolt free; can i work backwords and remove everything on the exhaust cam, along with the cas, and then remove the exhaust that way; or would that result into any problems?
please let me know; thanks
Old Nov 18, 2007 | 03:02 PM
robjeff25's Avatar
someone has to know;
Old Nov 18, 2007 | 05:46 PM
MINO's Avatar
Get a longer breaker bar and put a pipe on the wrench for more leverage.
Old Nov 18, 2007 | 05:56 PM
ethan169's Avatar
+1 on bigger breaker bar with pipe if needed. i had a similar problem when doing a top end build up on my 420A that was in my neon.
I have a nice impact with a beefy compressor that barely ever helps me in situations like this and the breaker bar will eventually get the job done with the right amount of leverage
good luck!!
Old Nov 18, 2007 | 06:05 PM
scottatyamaha's Avatar
I had this problem too on a friends car and it was no fun. We had two pretty big guys there and it took alot of leverage and time, but it finally came. Just dont bust a dent in your hood when it goes.
Old Nov 18, 2007 | 06:28 PM
robjeff25's Avatar
yeah; thanks for the advice; all i have here is my wife to help at this time
