LICP and FMIC compatibility
For those of you with the eBay FMIC, it works with the stock LICP correct? I understand the brackets are a bit of a pain, but whatever. I would also assume since the Buschur LICP is designed to work with the stock FMIC, I'd assume that the Buschur LICP would be compatible with the eBay FMIC?
I understand the eBay FMIC is far from being the best. My goal isn't big power. I'm trying to build an Evo with a good balance between power and suspension capability (350 - 400 AWHP is my goal, probably a 20g upgrade).... Well, it's proven that the eBay FMIC is in fact better than stock. By much? Not really, but it saves the hassle of cleaning out the stock FMIC from the oil build up and dresses up the extrior of the car a bit
So, what are you opinions about the bushur LICP being compatible with the eBay FMIC?
