motor build questions
Old Nov 29, 2007 | 02:29 PM
TREVORSEVOVIII's Avatar
ok so ive done some searching and havent found exactly what im looking for, im considering doing a motor build befor i step up to a bigger turbo, i would just rather do it first and be safe and be able to push the new setup harder than to get a bigger turbo middle of this next year and sling a rod or something and have to get a new block and everything, what do i need for a good reliable bottom end build on a buget. im not looking to make insane power in the end just something that can hold up to 500whp with no worries, ive seen stockers hold this much but ide rather just be safe. i just wanted to know if rods and pistons is all i need or what else is required. also what would be a round about price for the entire build including labor, thanks alot guys
Old Nov 29, 2007 | 02:44 PM
jmartinez1170's Avatar
Ill be more then happy to help you out with picking a setup on a buget ive done so for so many others.
If you would like shoot me a pm with your plans and goals for the car. Ill give you a list of parts and things that need to be done to make sure your happy with your setup.
