New Clutch Install now ACD PROBLEMS
Old Dec 3, 2007 | 06:57 PM
njragland's Avatar
So I got a new clutch and flywheel installed and now my ACD all goes green when I put it in gear!!!! A few have said too much air in the system and it needs to be bled?? Does that sound correct? If so... does anyone know of a place other then the dealer near Illinois that can do this??? And possibly some pricing?
Hope for some good feedback!
Old Dec 3, 2007 | 07:02 PM
E VOL IX's Avatar
no do it yourself... look under the car.. at the bottom of the center diff is a bleeder like on a caliper... get a friend to get in the car... fill the resevoir ALL the way to the top.... loosen the bleeder at the bottom and turn the ignition on hold the gas on the floor with the ignition on and i about 5 sec it will bleed out of the bleeder... keep bleeding till all air is gone... no need to pay for it
Old Dec 3, 2007 | 07:04 PM
KevinD's Avatar
bleed the ACD. it will take 5 minutes with even the most basic of wrenching skills. heres how:
1. prop up front of car.
2. get 10mm wrench, brake bleeding hose and container, and some dot 3 ATF fluid (i think thats what it is.. it says on the cap) make sure the filler tank is full BEFORE starting this process.
3. have a friend sit in drivers seat with keys
4. you crawl under car, put 10mm wrench on bleeder screw on the bottom of the transfercase (the TC is behind the engine, the front axles come out of it).
5. put hose over nipple.
6. have friend turn key to on positions and floor the gas pedal (don't start the car though). after a second or two, you'll hear a whining sound of the ACD motor going. when you hear that sound, crach the bleeder nipple and let the fluid and air come out, close nipple when you hear the pump stop. it will only run for about 4-5 seconds.
7. repeat process until you don't see any air coming out.
Old Dec 3, 2007 | 07:06 PM
njragland's Avatar
No special tool to this? I had emailed a company and they said I would need a special scan tool that most dealers have... to properly do this?
Old Dec 3, 2007 | 07:07 PM
njragland's Avatar
And this will fix my problem with all of them coming on you guys agree with that?
Old Dec 3, 2007 | 07:08 PM
E VOL IX's Avatar
yes you will be fine
Old Dec 3, 2007 | 07:09 PM
evo542's Avatar
i think it's automatic trans fluid, do not put in brake fluid if it's labeled ATF SPIII
Old Dec 3, 2007 | 07:11 PM
njragland's Avatar
It does say SP III on the cap....
Old Dec 3, 2007 | 07:27 PM
njragland's Avatar
http://www.lancershop.com/customer/p...0&cat=6&page=1
would these fluids be the right ones? these also
http://www.lancershop.com/customer/p...5&cat=6&page=1
which is the same just synthetic
Old Dec 4, 2007 | 07:34 AM
2theMAX's Avatar
NO! Do not put that in your car. Read your manual. This is what you need.
Old Dec 4, 2007 | 07:42 AM
rcheung's Avatar
No, that is gear oil. You need automatic transmission fluid SPIII.
Old Dec 4, 2007 | 07:55 AM
Mr. Evo IX's Avatar
You need a quart of the diamond atf pictured above. The reason that someone said that you need a special tool is because if you have the MUT tool you can directly control the ACD pump and prime it very easily. If you dont have the MUT tool (laptop with software for mitsu techs), then you have to bleed it 5 seconds at a time as described above.
Old Dec 4, 2007 | 08:08 PM
njragland's Avatar
Anyone have a site where I could order the fluids listed above?
Old Dec 4, 2007 | 10:00 PM
Brian's Avatar
Who did your clutch install?
Also Diamond ATF SP 3 can be picked up at mitsu.
Old Dec 7, 2007 | 01:12 PM
njragland's Avatar
lol the dealer I called said they only sell it by the gallon
