help!! i have questions about my 2.3 build
Old Dec 3, 2007 | 09:12 PM
totalsbl14's Avatar
I bent a rod in my evo and decided to go with the 2.3 stroker kit by AEMs. to my understandin in order to get the maxium horsepower out of the 2.3 stroker upgrade the turbo must also be upgraded beacuse of the compression. so i was woundering what the best turbo without having to upgrade my wastegate and everything else. Im lookin for just a turbo that i can just bolt on and push out 27 psi of boost.. if there is such a thing.. i already upgraded my fuel pump and to my understandin the injectors can hold... ANY info would help and get me on the way to a great build. THANKS
Old Dec 3, 2007 | 11:21 PM
RevMoto's Avatar
You don't have to upgrade. That is a choice you can make. What year car do you have? That might help. Since you have a 2.3 really any turbo will work. Any certain goals you are trying to reach or just somebody said you need to replace it?
