**** Car revvs by itself HELP *****
Old Dec 5, 2007 | 06:38 AM
CrackerJackToy's Avatar
Do a boost leak test bro. More than likely you popped off a vacuum line where you cant see it, or maybe multiple vacuum lines. Try that and then get back to us.
Old Dec 5, 2007 | 06:42 AM
MR Turco's Avatar
Sounds like the car went into some sort of limp mode. My roommate's suby did the SAME things (cable throttle too, not throttle by wire) when his Idle Air Controller died. The car kept revving itself to keep itself running. I would check your idle air controller, it may have crapped out.
Like you said if it is a vacuum leak it will just run high and lean.
Also worth mentioning: We had just swapped the motor on my roommates car. It had been sitting for a month and there was some crap in the IC causing it to get into the IAC and it bound up (very bad design). So since you also had some major work done it might have gotten some crap in the IAC. But like yours, his car drove fine for about a mile then it started acting up.
Old Dec 5, 2007 | 06:46 AM
scottatyamaha's Avatar
Sounds like your mani broke and is sucking in massive amounts of air.
Old Dec 5, 2007 | 09:41 AM
chargespeedMR's Avatar
yea the cars at my friends house. I will check it out later tonight and i'll get back to you guys and let you know whats up.
Old Dec 6, 2007 | 06:03 PM
Ok so last night I was checking out my car and found out what the problem was...dumb magnus intake manifold.
Check out the pics
Old Dec 6, 2007 | 06:21 PM
byt's Avatar
byt
whoa!
Old Dec 6, 2007 | 06:29 PM
yes pretty crazy huh
Old Dec 6, 2007 | 06:34 PM
DarkMastyr's Avatar
I don't think this is the first time Magnus manifolds have popped at the weld either... can't recall an exact case though.
groove304's Avatar
wtf
Old Dec 6, 2007 | 06:54 PM
mplspilot's Avatar
Holy phuk!!!
Old Dec 6, 2007 | 06:56 PM
SuprEVO's Avatar
WTF is right!!! that SH*T is crazy
Old Dec 6, 2007 | 07:01 PM
iturregui's Avatar
Unbelievable
Send that pic to the manufacturer
Old Dec 6, 2007 | 07:07 PM
evoDON's Avatar
thats ridiculous. I guess no one should buy Magnus manifolds anymore in fear of exploding there engine when this happens
Old Dec 6, 2007 | 07:45 PM
SWOLN's Avatar
Dooooooooooooooddd I have some JB Weld over here, roll it by. We can fix it.
Old Dec 6, 2007 | 07:50 PM
chaotichoax's Avatar
that's bananas
