high knocks running on toulene
Old Dec 22, 2007 | 01:12 AM
xpro's Avatar
well i tought that toulene mixture would have improved knocks,especially on high boost.
yestreday i tried 5%toulene&xylene mixture on full tank,and afterwards went for a drive with dattalogger,and the knock sum was unbeliavable.anywhere from 11 to23.
usually i only get 1-2 knocksum on wot with normal fuel.
car actually runs smoother,but doesnt go well in WOT.
did anyone else had this problem??
thanks
Old Dec 22, 2007 | 02:19 AM
Dapper Dan's Avatar
are you sure you used the right stuff?
Old Dec 22, 2007 | 04:48 AM
recompile's Avatar
From http://elektro.cmhnet.org/~charlie/p.../toluene.html:
Because toluene is such an effective anti knock fuel it also means that it is more difficult to ignite at low temperatures. The Formula 1 cars that ran on 84% toluene needed to have hot radiator air diverted to heat its fuel tank to 70C to assist its vaporization. Thus too strong a concentration of toluene will lead to poor cold start and running characteristics. I recommend that the concentration of toluene used to not exceed what the engine is capable of utilizing. i.e. Experiment with small increases in concentration until you can no longer detect an improvement.
Old Dec 22, 2007 | 06:10 AM
cfdfireman1's Avatar
What are your AFRs? Stoich for toluene is around 11:1 so you may have to add some fuel.
Old Dec 22, 2007 | 06:34 AM
xpro's Avatar
i dont have the wideband to measure afr,and stuff i used i got it from a chap who works in the paint store,they use it for diluting paints,so i dont know if thats the right stuff.
Old Dec 22, 2007 | 07:43 AM
djh's Avatar
djh
Was this a back-to-back test? When was the last time you logged a run on straight pump gas? As I've posted a few times, the 114 octane number for toluene doesn't mean what you think it means. A better R+M/2 value is 100, so 5% in 93 octane gives you a whopping 93.4 octane mix. In other words, you were pretty much still running on pump gas and maybe that particular pump gas wasn't so hot and you would have gotten the same knock count.
FYI, where does the 114 octane number come from? It's a "blending" octane number, measured in the 1940s when straight-run, distillate gasoline (before catalytic cracking and hydroformation) was typically 50 to 60 octane. To get a blending octane number you run a 20% mix of the test fuel in a 60/40 mix of "iso-octane" and n-heptane (60 octane by definition), measure the octane number, and extrapolate to 100% test fuel. So while a little toluene really helps out a poor quality base fuel, it doesn't have the same effect when you start with modern gas (which is already 20 to 30% aromatic). I've never come across any measured octane numbers for pure toluene.
Dave
