NEED HELP! Is my ACD broken?
Old Dec 24, 2007 | 11:28 AM
MattevoVIII's Avatar
well idk how it happened but
out of nowhere i got engine check which later on followed the 3 green dots for the acd to light up not just one?...
and the car has following synptoms:
-when i turn to the left sharp car slows down by a lot like its braking
-idle is not at steady rpm varies 1500rpm up and dwon whaen driving the car in nutral
and very often rpm stays at 3k very weird
also the car feels like its messed up in the acd computer seems like it doesnt know where to distribute the tourge?
please help thank you
Old Dec 24, 2007 | 11:34 AM
cssaddictm4's Avatar
Does the car feel like the steering wheel is going to be ripped out of your hand while taking a corner? ACD pump could be messed up, or worse depending. Whats the ACD fluid level like?
Old Dec 24, 2007 | 11:41 AM
you know what that makes sense cuz on the striaght line its normal
i dont take corrners fast now im afraid but i belive what you described would be the effect
how i check the fluid level? if not enough how i add? where? udner the car?
Old Dec 24, 2007 | 11:51 AM
W0459732's Avatar
dude just be safe and get it checked out at the stealership. Is ure car still under warranty?
Old Dec 24, 2007 | 12:00 PM
its not
but i called adam from devo tuning he siad i can come by wed...cuz of the holidays...
Old Dec 24, 2007 | 12:15 PM
ACD Fluid is in the container under the hood behind the drivers side head light, redish fluid.
Old Dec 24, 2007 | 12:26 PM
if im missing fluid? what do i need to buy exactly whats the brand or name ?
Old Dec 24, 2007 | 12:45 PM
Replied to your PM
Mitsubishi Diaqueen ATF SP3
Old Dec 24, 2007 | 07:39 PM
thedragon's Avatar
my acd hasnt worked in 2 years car runs great
Old Dec 24, 2007 | 07:54 PM
eag36's Avatar
Jack your car up and try to shake your wheels back and forth. You could have a really bad wheel bearing. That would only explain the ACD lights if you broke off an ABS sensor on one of the wheels which would mean you have a wheel way out of wack. I think you'd feel it while driving straight though.
Even so, before you drive anywhere do that. Otherwise your wheel could lock up and you could be s.o.l. up pretty quick.
Old Dec 24, 2007 | 08:16 PM
car drives perfect just u can feel the car has problems distributing power its struggling to decide theres no control but its not that bad... only on turns it feels to lock up
Old Dec 24, 2007 | 08:18 PM
akemi27's Avatar
i had mine busted for a good half a year or so - but luckily had it covered per warranty....
boostGotMeLaid's Avatar
if u need a new acd pump i have one for ya bro willing to help u out cheap as **** holliday hurt the old wallet lmk
Old Dec 24, 2007 | 08:41 PM
eag36's Avatar
It doesn't really make sense to me that the ACD would be causing you steering problems. If I'm not mistaken, the ACD controls the center diff which is front and rear power, not left to right which would be causing you problems when turning. Left to right torque is distributed using limited slip differentials which doesn't actually send torque one way or another, but just locks up if it senses slip.
Although I guess if your center diff were in lock-up you would feel it when you were turning.
I think you either have two different problems... one causing the turning/ACD issues and the other causing the weird idle. Or you have one messed up ECU.
My vote right now is for a messed up ABS/Wheel speed sensor. This would make the ACD fault out because it cant sense wheel slip and thinks a wheel is not spinning or is continually slipping.
What was the code from your CEL???
Old Dec 24, 2007 | 08:49 PM
KcEvil8's Avatar
but if the ABS sensor is bad..it'll kick on the ABS light on the dash
