Intercooler piping question
Old Dec 25, 2007 | 09:22 PM
EJEvo's Avatar
I've seen threads stating those lightweight batteries don't do well in cold climates. Not sure where "Warrenton" is - TX, MO, VA.
Old Dec 25, 2007 | 09:23 PM
stev08's Avatar
yeah i was actually going to get a yellow top optima so i can hook my sound system up to it as well.
Old Dec 25, 2007 | 09:24 PM
Evoryder's Avatar
Red Top/ yellow top...sick batteries. Keep it in the trunk.
Old Dec 25, 2007 | 09:28 PM
stev08's Avatar
I just need a different relocation kit that comes with 2 gauge wire
Old Dec 25, 2007 | 09:30 PM
Evoryder's Avatar
give me the kit.
All you need to do is replace the thinner wire with the thicker 2gauge wire. Gold connectors. Good luck with it. Have the battery checked, it may be on its way out as the other guy suggested. Slow / labored starts are definite signs of a battery on it's way out.
Old Dec 25, 2007 | 09:31 PM
thatsMR2u's Avatar
make sure if u ever want to track ur car what the specs are for relocating your battery to your trunk
Old Dec 25, 2007 | 09:34 PM
stev08's Avatar
ok thanks
Evoryder's Avatar
kill switch.
Old Dec 25, 2007 | 09:35 PM
04AWDTURBOEVO's Avatar
May be the current battery is going bad little by little.
You can replace it with a new one, Red or Yellow top like someone mentioned.
Or, you can buy a small Battery Kit; However, someone here also mentioned they may not work so hot on the cold weather, I don't know.
For the price of either of those new batteries, you can buy a new upper Intercooler Pipe, . This is what I would do. And relocate the battery back to the front.
Seems you are not happy with it in the Trunk.
Old Dec 25, 2007 | 09:40 PM
Evoryder's Avatar
Why not keep the space up front free and the weight in the back? isn't the motor, transmission, transfercase enough weight up there?
Old Dec 25, 2007 | 09:47 PM
stev08's Avatar
yeah im going to go with new 2 gauge wire and yellow top optima
stev08's Avatar
so if I want to go to the track I will need a kill switch?
Old Dec 25, 2007 | 10:02 PM
Sure, may as well, since the battery is back there allready.
Old Dec 25, 2007 | 10:20 PM
stev08's Avatar
thanks for the advice guys
Old Dec 25, 2007 | 10:22 PM
Evoryder's Avatar
yes. They will inspect your under your hood to check for battery...if it's in the trunk then you have to have an approved kill switch.
