Turbo Experts, HELP
Old Dec 27, 2007 | 11:45 AM
tommyevo's Avatar
Turbo Experts, HELP
First Thread Ever, anyway when i get on the boost and go to shift to the next gear i hear this loud fluttering noise coming from the drivers side front. It almost sounds like the factory recirc. valve is not letting it vent off properly, also is there a way to test the factory blow off? Just don't want to damage my turbo.
Old Dec 27, 2007 | 11:52 AM
TeStUdO's Avatar
Ummmm sounds like the BOV is doing its job.
Old Dec 27, 2007 | 12:01 PM
MR Turco's Avatar
I know the evo 8 recirc valves are crappy. I cannot recall issues other then not holding boost though. It could be a bad recird valve. You can test it with a brake bleeder kit if you have one. Hook it up to the vacuum fitting and see if the valve opens up. If you have a gauge see what the reading is. I know on a subaru the valve opens at around 18in/hg, ours should be similar.
Old Dec 27, 2007 | 12:04 PM
awboostjunkie's Avatar
got a boost gauge, would help to know what it's reading when this happens
Old Dec 27, 2007 | 12:19 PM
tommyevo's Avatar
I've checked my boost gauge, it does'nt make the noise if its in a vacuum and i can't hear the blow off at all anymore. With a cone filter you can hear even the factory valve blow off. Also its boosting just fine, but i don't want to keep boosting until i can figure out whats wrong.
Old Dec 27, 2007 | 12:23 PM
MR Turco's Avatar
like i said, test the recirc valve. They do go bad. Or if you have a buddy with an evo, borrow his and see if it fixes the problem. I recommend if it IS surging not to go into boost. I would also check your vacuum lines. My buddy had a small slit in his line that caused his to do the same thing. It wouldnt hurt to change out the plastic crappy recirc valve anyway.
Old Dec 27, 2007 | 01:01 PM
tommyevo's Avatar
Any recomendations on valves, i've been looking at the greddy type rs if this turns out to be the problem. Thanks for your input.
Old Dec 27, 2007 | 01:39 PM
housedj's Avatar
i think the '05 MR & all the '06 stock bov's are metal like the 1st gen DSM ones. u can probly pick 1 up off ebay. go thru & check all ur vacuum lines, i/c piping for leaks. or look for a nice quality recirc valve online. if u want a VTA bov, u will need the HKS EIDS or a good tuner to adjust ur idle to use it correctly on stock ecu. i run a VTA but i also have a racegas tune at 25+psi on my stock ecu
Old Dec 27, 2007 | 01:40 PM
MR Turco's Avatar
I would just get the metal OEM valve. Don't run a VTA BOV.
Old Dec 27, 2007 | 02:03 PM
sparky's Avatar
As TesTudo says "it's working fine". They tend to get noisier when the weather gets colder and it's even more noticeable with an open air element.
Old Dec 27, 2007 | 02:12 PM
matt6g72's Avatar
It definately sounds like compressor surge to me. Take off your bypass valve and see that it still opens. If you can't hear the blowoff anymore and you hear a fluttering noise, that most likely means the valve is not letting off the compressed air and it is being forced back through the turbo- AKA compressor surge.
Old Dec 27, 2007 | 02:16 PM
fromWRXtoEVO's Avatar
No,the 05 MR had the plastic one. The Evo IX were metal.
Carlos
Old Dec 27, 2007 | 02:27 PM
housedj's Avatar
Carlos
that's kinda what i was thinking. just validated that info.
this is what i was thinking of:
http://www.lancershop.com/customer/p...&cat=27&page=1
shogun
11
Feb 11, 2011 06:21 AM
DKC6691
Feb 2, 2011 10:44 AM
Nasty Evolution
Nov 16, 2010 08:09 PM
xmaciek82x
Midwest Region
Oct 17, 2009 09:07 AM
MR Dan
Dec 24, 2008 12:31 AM
