ok so i ordered cams and cam gears
like the title says i got some cams and cam gears, i was needing to know is there any seals,gaskets,or specialty tools to do the install? or any extra parts? thanks
How new is your motor? When i rebuilt mine i re-used the valve cover gasket since there was only 7,500 miles on the motor. You will need to buy some sealer to re seal the valve cover, i recommend "ultra black", its a gasket adhesive and it is all i use at my shop as far as that goes.
You will be taking the timing belt off in order to switch your cams and cam gears, it can be a little tricky putting the timing belt on but you do not "need" a special tool if you are experienced with this type of work.
you need this tool http://lancershop.com/customer/produ...&cat=15&page=1
and these parts http://lancershop.com/customer/produ...&cat=15&page=1
follow these instructions very carefully http://evomoto.com/tech_info.php?tec...3462909f3d947a
probably some cam seals would be a good idea and maybe a new valve cover gasket. like mentioned above you can get the timing belt back on without the tool but if i was you id upgrade the timing belt as well. just my opinion but i think whenever adding cams its a good idea to replace the t-belt as well.
The timing belt tool makes life easier if it is your first time doing this kind of job but you do not "need" it. I also just realized you have a 2003 so it would be wise buying a new valve cover gasket, i recommend buying a gasket sealer so you can minimize leaks.
