how much boost can a stock evo handle?
Old Jan 9, 2008 | 05:45 AM
anton406's Avatar
i have full exhaust, AFC, filter, tuned to 260 whp. im currently at 1.0 bar. how much can i increase it to? thanks!
Old Jan 9, 2008 | 05:49 AM
Nomad4g63's Avatar
depends which evo???! Evo 8 or 9?
Old Jan 9, 2008 | 06:47 AM
TouringBubble's Avatar
VII ...
You can likely run around 21 - 22 psi safely with a good tune. That means about 1.15 bar.
Old Jan 9, 2008 | 06:50 AM
grillpt's Avatar
What grade fuel do you have in the Philippines?
Old Jan 9, 2008 | 06:52 AM
ovenmit331's Avatar
Originally Posted by TouringBubble
VII ...
you're WAY off...
21psi = 1.45bar
22psi = 1.52bar
Old Jan 9, 2008 | 12:36 PM
MRQ06's Avatar
96 octane on selected pump gas stations. Dnt know about the quality though ha ha.
Old Jan 9, 2008 | 12:44 PM
WaxThis2005's Avatar
Someone that wants to be safe, good to see!
Old Jan 9, 2008 | 12:46 PM
V.8MR's Avatar
If your tuned then why would you want to turn the boost up?
Old Jan 9, 2008 | 04:27 PM
Murf's Avatar
your not running much boost only 1.0 bar 14.6 psi Try this..get fuel pump, and up boost to 18 psi 1.24 bar. tune for that boost . Make sure that tuner uses wideband to monitor afr's. try the afr's at 11.1 then slowly lean out and add timing. Repeat cycle to desired boost. Remember not to go nuts on the timing
Old Jan 9, 2008 | 08:47 PM
shivaswrath's Avatar
it largely depends on your tune, you can run up to 26 psi spikes on a stock turbo with a safe tune. . .
Old Jan 9, 2008 | 08:49 PM
evokel's Avatar
you dont have a stock evoo
evo86's Avatar
you can go up to 1.5 bar.
Old Jan 9, 2008 | 08:51 PM
Tarmacisback69's Avatar
hrmm depends which fuel u use.
Old Jan 9, 2008 | 08:54 PM
evovin's Avatar
22psi with good tune and good gas. Have you ran it to PDRF yet?
Pare pm me if you have any questions...
Old Jan 9, 2008 | 09:04 PM
joedr's Avatar
EvoM Moderator
I run 25-26 PSI peak.... 22-23 PSI at redline on 93 OCT. Two years and still good to go!
When I was in Korea, there were some pumps on 96 or 98 (Can not remember exactly) but a guy had an Evo 7 and was running 27 PSI on a stock turbo. Tuned by HKS Korea.
Note: Not sure about the quality or if the car was pushed to the max.
