35r
Old Jan 9, 2008 | 09:36 PM
EvoVIII808's Avatar
35r
Where can i get a rebuild kit for my RNR GT35R turbo? Smoking white under boost, so i know it needs to be redone.
any help would be good. hope to get this done within 2 weeks.
Thanks in advance
Old Jan 9, 2008 | 09:48 PM
EvoHung's Avatar
hmm... are you sure your turbo is bad? I'm not doubting your knowledge, I just want to ensure that you check all other possibilities. Good luck man.
Old Jan 9, 2008 | 10:31 PM
MRfabolous's Avatar
you sure it is not your headgasket....do a leak down test and comp test start there
Old Jan 9, 2008 | 11:50 PM
EvoVIII808's Avatar
98.6% sure. I had it on before water got into it when it was storming and it started to smoke. Smell like burnt oil, and was a white color. Smokes alot under boost. I swaped the 35 back to Stock, and no smoke.
Just reinstalled it to make sure, and the smoke is back. So i am sure its the Turbo. I also Ported the exhaust, installed cam gears, APR head studs, and replaced all Gaskets and Seals while installing the Turbo.
Old Jan 10, 2008 | 07:50 AM
jmartinez1170's Avatar
Do the HTA treatment from Force Performance. Its around $480 i think
Old Jan 10, 2008 | 12:54 PM
EvoVIII808's Avatar
Seems like they only rebuild turbos purchased from them. Anyone else got some place to get a rebuild done?
