Cosworth IX Idle Problems....
Old Jan 13, 2008 | 06:38 PM
vboy425's Avatar
Originally Posted by Tarmacisback69
hks 272 mivecs installed here, idles smoother then stock tuned by mike @ atlantic motorsports.
because HKS mivec cams doesn't have not much lift and whp gain either. Cossie have the best that we have seen on our shop dyno. Idle better than stock, come on bro get real here.
Old Jan 13, 2008 | 07:45 PM
06ravenmr's Avatar
i would call turbotrix back and tell them to fix ur ****.
Old Jan 13, 2008 | 09:39 PM
90GSXDan's Avatar
Oh trust me I am. Today I decided to get on it alittle, did a small pull from third gear and stopped at 7k. Got home and my car started smoking alittle. Its definitely coolant leaking somewhere. I cant check where right now as it is raining/slush and its 12:37 AM. Only problem is I cant take off work anymore and they are in New Jersey and Im on long island, NY. Im going to ask for a refund so It can atleast cover half of my tune and the fixing of the leak. TTR FTL
Old Jan 13, 2008 | 09:43 PM
Boost3dxEvO's Avatar
Bro... It is most likely in the tune... get a REAL tune from Mellon Tuning..
He tuned my Cosworth M2's PERFECT. (:
Old Jan 13, 2008 | 10:39 PM
James@DSR's Avatar
Cosworths are pretty aggressive. Must be the tune though shouldnt fluctuate like that though.
James
Old Jan 13, 2008 | 10:48 PM
hamx0r's Avatar
if you threw a check engine light...it can either be your front o2 sensor or the cam angle sensor most likely...since that is what has been touched...but you better hope it is neither and +1 about you should of gone to ivey... some kid when i was there got tuned 1 week prior by turbotrix and he had to bring his car to ivey to get a new tune because their tune was making his car run like crap
Old Jan 14, 2008 | 02:49 AM
SpeeDeviL's Avatar
+1 for that, am getting cosi cams, O2 housing and FMIC, and Mellon well tune my car
get your car fixed first, then contact Mellon
Old Jan 14, 2008 | 07:41 AM
06ravenmr's Avatar
i personally got a good tune from turbotrix so i cant say nothing bad but dang the coolant def aint good. let me know how things work out. i just purchased a set of the m3's with supertech springs and retainers. i was gonna have them install and tune mine but now im a lil worried.
Old Jan 15, 2008 | 07:58 PM
Tarmacisback69's Avatar
I have yet to see any cossis barrel roll over the hks 272 mivec cams in hp or torque
Old Jan 15, 2008 | 07:59 PM
SlowSportSedan's Avatar
its not just the cams... its the injectors too
take the car back and let them fix it..... **** happens...
Old Jan 15, 2008 | 08:32 PM
TTP Engineering's Avatar
We tuned cosworth m2's to 373/371 on Saturday, 93 octane pump gas. Brotherz Racing Dynojet 424x dyno.
Old Jan 16, 2008 | 07:59 AM
20psiMR's Avatar
Seriously? Must not be looking very hard...
Car I tuned the other day with just buschur tbe, intake and 02 with the cosi IX cams made 380/400 on a dynojet. Mine was on the same dynojet without o2 and using hf cat and Works drop in filter/tbe. The HKS's arent making crap.
Old Jan 16, 2008 | 08:26 AM
06ravenmr's Avatar
any update on if turbotrix is gonna fix ur car??
Old Jan 16, 2008 | 12:40 PM
HaVoC RR's Avatar
turbotrix lmao the horror stories go on and on and on
Old Jan 16, 2008 | 03:13 PM
90GSXDan's Avatar
Turbotrix is going to fix my coolant leak this sunday, even though they are closed. As for the tune, they said to just raise my idle with the idle screw. Im not into that so Ive already contacted Mellon about a retune. While im at Turbotrix im going to have him double check over my timing and boostleaks to make sure there isnt a leak causing the bad idle/surge, then go from there. I dont think its a boost leak seeing as Im holding boost just fine and spiking to 25psi.
Ill keep you updated!
Dan
