600hp possible on 93 possible???
Old Jan 13, 2008 | 03:56 PM
evo9 ate u's Avatar
got a evo 9 my goal is 600hp on pump gas i want to go with ams but still lookin around, has anybody accomplished this yet. opinions?
Old Jan 13, 2008 | 04:00 PM
evilbada's Avatar
I'm figuring you are talking about 600whp.
With straight pump gas, you will not hit that power level unless you are adding some alcohol to the mix.
Maybe if you use a rediculously large turbo, you may reach your goal with no usable power band and 7000rpm spool.
Plan on using meth or race gas if you want to reach 600whp.
Old Jan 13, 2008 | 04:01 PM
boostin06ggevo's Avatar
Yea I thinks its pretty much possible but it depends on what size turbo and what engine managment and built block or stock all these factors factor in the equation for you meeting 600hp on pump gas.
evo9 ate u's Avatar
i figured alky injection is needed
Old Jan 13, 2008 | 04:03 PM
evo9 ate u's Avatar
i figured stage 3 block and head probably 35r or 37r
Old Jan 13, 2008 | 04:04 PM
evilbada's Avatar
oops, I forgot about Buschur's HTA35r.
With that turbo and supporting mods from Buschur racing + David Buschur's tune,
you can definitely reach 600whp on straight pump on dynojet. 28-29psi.
Old Jan 13, 2008 | 10:13 PM
EVOlutionary's Avatar
This will not happen on straight pump gas unless you go with a 42R. If you use meth injection then it will be possible with an AMS 37R kit. . .
EVOlutionary
Old Jan 14, 2008 | 09:36 AM
evilbada's Avatar
EVOlutionary
You are wrong. You don't even need a 37r.
Just look for some of the HTA35r thread by Buschur racing.
Old Jan 14, 2008 | 09:45 AM
AWD Motorsports's Avatar
anything is possible but is it safe.. NO
Old Jan 14, 2008 | 09:52 AM
SlowSportSedan's Avatar
with alc injection you can do it with a 35r.... 4 Wheel Slide is trying to do with a 3065
Old Jan 14, 2008 | 09:54 AM
Not on ONLY 93 octane with NO alcohol or water injection. The original 35R would only hit in the low 600's with race gas, so there is no way even the new HTA35r will make that on 93 octane.
Old Jan 14, 2008 | 09:55 AM
turboDan's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=307405
AndyBandy's Avatar
yeah i wouldnt try 600 on pump, its just not the most usable power band.
just get a race gas tune for 600 whp and when you use 93, you'll still be making good power. I personally prefer alky injection .
Old Jan 14, 2008 | 10:04 AM
Thanks, you just proved my point - the car in your link made 530's on 93 octane and only 590 on 93octane + alcohol injection. Still not 600 . . .
Old Jan 14, 2008 | 10:09 AM
520hpsti's Avatar
considering what dyno that is on. id consider that 600
