Cosworth M3 Idle Video?
i doubt that it would benefit someone on a stock turbo... I think the m1's are agressive enough
Which valve/retainer kit will you use? probably i will go with supertech doubles...
yo
Itzwolf was talking about my car. I am going to use Brain Crower singles springs and retainer kit, Scott(TTP) told me they'll be fine. I am not planning on spining it more than 8200rpm anyways. Just did Super duals in car not removing head and it wasn't fun, bottom spring plate was bigger than valve seat so had to pull and install new valve seals also. But single will slide right over them.
May install the M3's on Monday since it a holiday Thanks (MLK) for the day off
I am currently using GSC 280's.
Then gotta drive to Orlando tyo have Jestr fine tune it.
i went with the superdeck doubles. u will also need to purchase new seals as well cuz they wont work with the old ones. cost me a total of 320 for springs, retainers and the valve seals.
i dont really know whats gonna happen. ill let u know what kind of power i make when i get back from deployment. hopefully its good if not then i guess ill just have to buy the turbo kit sooner then planned.
best of luck to you on your deployment... will be patiently awaiting the results!
Buschur has my block and head built. I talked to Nick and we are upgrading my current Cosworth intake cam to the M3.
When I was at the shop on friday Dave showed me my stage 3 aluminum rod block and head. I told Dave about the cam Nick ordered for me and he said the springs in the head now (i will not say what he put in it) would not be enough for this cam. So I guess I am getting the same spring treatment as the black car
I will have this all done hopefully with in the next month or 2
your project is pretty interesting and it will clearly show the gains of a much more aggressive intake cam with higher lift and duration...
alpinaturbo
May 2, 2011 08:01 PM
alpinaturbo
Apr 13, 2011 01:44 PM
